[PostGIS] #6124: 3.7.0rc1 docs build failure without error message (was: 3.7.0rc1 compile failure on NetBSD)
trac at osgeo.org
Fri Sep 4 07:20:25 PDT 2026
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.7.0
Component: documentation | Version: master
Resolution: | Keywords:
Changes (by gdt):
* cc: gdt (added)
* priority: medium => blocker
* summary: 3.7.0rc1 compile failure on NetBSD => 3.7.0rc1 docs build
Comment:
This is about the docs build. I retitled away from NetBSD because
there's no evidence this is OS specific -- just that I don't happen to
have random non-documented things installed that are present in some other
environments.
There are probably three problems. One is that there are some new
(relative to 3.6) dependencies to build the documentation, and those are
not noted in NEWS and the in-distfille build instructions reachable from
README. Best practice for packaging is to hide/withdraw all things which
are not declared dependencies, so this likely affects multiple packaging
systems.
The second is that this arguably should have been caught by CI, which
should only install documented dependencies.
The third problem is that when the secret dependency isn't available, the
docs build just skips a step, apparently -- but it's later fatal that it
didn't happen. If it's a dependency, then configure or build should fail
with an explicit error.
For the release, the docs need fixing. The rest should happen, but it's
less critical.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6124#comment:1>
