[PostGIS] #6124: 3.7.0rc1 docs build failure without error message
PostGIS trac at osgeo.org
Mon Sep 7 18:02:43 PDT 2026
  Reporter:  robe           |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  blocker        |  Milestone:  PostGIS 3.7.0
 Component:  documentation  |    Version:  master
Resolution:                 |   Keywords:
Comment (by robe):
 Confirmed not a freebsd specific issue.  I guess cause our cis that build
 the docs build the visual-examples as a standalone step, but seems if you
 call
 gmake -C doc html
 It never tries to run the visual-examples step, just tells you that you
 need to run it.
 Are you able to run
 make -C regress visual-examples
 Just want to confirm we aren't missing any known dependencies.  Note that
 the visual-examples requires a running PostgreSQL instance too as it tries
 to run thru the examples in the docs.
 I'm not setup locally to build the docs so that step fails for me.
 Anyway I'll sort this out before I push an rc2.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6124#comment:2>
