[PostGIS] #6124: 3.7.0rc1 docs build failure without error message
trac at osgeo.org
Mon Sep 7 18:43:19 PDT 2026
Reporter: robe | Owner: robe
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 3.7.0
Component: documentation | Version: master
Resolution: fixed | Keywords:
Changes (by Regina Obe <lr@…>):
* resolution: => fixed
* status: new => closed
Comment:
In [changeset:"8614c07a40178981ea16e4ecf4be85d0156ccc17/git"
8614c07a/git]:
{{{#!CommitTicketReference repository="git"
revision="8614c07a40178981ea16e4ecf4be85d0156ccc17"
Don't give a confusing error when visual-examples has not been run yet
Give a simple note that it needs to be run to build docs and then stop
Also note in the NEWS that visual-examples is a requirement for doc
building
Closes #6124 for PostGIS 3.7.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6124#comment:3>
