[SCM] PostGIS branch master updated. 3.7.0rc1-51-gfb915a676
Tue Sep 8 10:15:39 PDT 2026
the project "PostGIS".
       via  fb915a6760c84984f86a671a306ee83fd38f413b (commit)
       via  a9634c0c735ae492efb3099d0cff0d26d0ce74be (commit)
      from  df51a62808292e9917409d2019ccd12ee700681b (commit)
revisions in full, below.
commit fb915a6760c84984f86a671a306ee83fd38f413b
Merge: df51a6280 a9634c0c7
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Tue Sep 8 10:15:37 2026 -0700
    Merge pull request '[raster] Enforce postgis.enable_outdb_rasters' (!779) from Komzpa/postgis:codex/raster-outdb-guc-20260907 into master
    Bind postgis.enable_outdb_rasters to the core offline-band guard used by
    metadata and pixel reads. The documented default off setting now takes effect
    after upgrade, while explicitly enabling out-db rasters preserves those reads.
    In-database rasters are unaffected.
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/779
commit a9634c0c735ae492efb3099d0cff0d26d0ce74be
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Mon Sep 7 23:25:33 2026 +0400
diff --git a/NEWS b/NEWS
index 069a05a2d..db1d0173f 100644
--- a/NEWS
+++ b/NEWS
@@ -132,6 +132,10 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
 * Bug Fixes *
+ - [raster] Make postgis.enable_outdb_rasters=off enforce offline-band
+          metadata and pixel-read restrictions after upgrade
+          (reported by Sarath Kumar, IITM Pravartak Security Team;
+          fixed by Darafei Praliaskouski)
  - GH-1175, Guard missing operands before reading node tags in
           spatial selectivity estimation (Maksim Korotkov)
diff --git a/raster/rt_pg/rtpostgis.c b/raster/rt_pg/rtpostgis.c
index 4c8bd1a3f..fba4adfaf 100644
--- a/raster/rt_pg/rtpostgis.c
+++ b/raster/rt_pg/rtpostgis.c
@@ -481,7 +481,8 @@ rt_pg_vsi_check_options(char **newval, void **extra, GucSource source)
 static char *gdal_datapath = NULL;
 static char *gdal_vsi_options = NULL;
 static char *gdal_enabled_drivers = NULL;
-static bool enable_outdb_rasters = false;
+/* Defined in rt_band.c and used by the offline-band access guards. */
+extern bool enable_outdb_rasters;
 static bool gdal_cpl_debug = false;
diff --git a/raster/test/regress/rt_outdb_guc.sql b/raster/test/regress/rt_outdb_guc.sql
new file mode 100644
index 000000000..1547c7d65
--- /dev/null
+++ b/raster/test/regress/rt_outdb_guc.sql
@@ -0,0 +1,88 @@
+CREATE FUNCTION outdb_guc_can_read_metadata(rast raster)
+RETURNS boolean
+AS $$
+BEGIN
+	PERFORM ST_BandFileSize(rast, 1);
+	RETURN true;
+EXCEPTION WHEN OTHERS THEN
+	RETURN false;
+END;
+$$ LANGUAGE plpgsql;
+CREATE FUNCTION outdb_guc_can_read_pixel(rast raster)
+RETURNS boolean
+AS $$
+BEGIN
+	PERFORM ST_Value(rast, 1, 1, 1);
+	RETURN true;
+	RETURN false;
+END;
+DO $$
+BEGIN
+	PERFORM postgis_raster_lib_version();
+END;
+CREATE ROLE outdb_guc_regression_guest;
+GRANT SELECT ON raster_outdb_template TO outdb_guc_regression_guest;
+GRANT EXECUTE ON FUNCTION outdb_guc_can_read_metadata(raster) TO outdb_guc_regression_guest;
+GRANT EXECUTE ON FUNCTION outdb_guc_can_read_pixel(raster) TO outdb_guc_regression_guest;
+SET postgis.gdal_enabled_drivers = 'GTiff';
+RESET postgis.enable_outdb_rasters;
+SHOW postgis.enable_outdb_rasters;
+SET ROLE outdb_guc_regression_guest;
+SELECT 'off_metadata', outdb_guc_can_read_metadata(rast)
+FROM raster_outdb_template WHERE rid = 1;
+SELECT 'off_pixel', outdb_guc_can_read_pixel(rast)
+SELECT 'off_indb_pixel', (
+	ST_Value(
+		ST_AddBand(
+			ST_MakeEmptyRaster(1, 1, 0, 0, 1, -1, 0, 0, 0),
+			1, '8BUI', 7, 0
+		1, 1, 1
+	) = 7
+RESET ROLE;
+SET postgis.enable_outdb_rasters = true;
+SELECT 'on_metadata', outdb_guc_can_read_metadata(rast)
+SELECT 'on_pixel', outdb_guc_can_read_pixel(rast)
+RESET ROLE;
+SELECT 'reset_metadata', outdb_guc_can_read_metadata(rast)
+SELECT 'reset_pixel', outdb_guc_can_read_pixel(rast)
+RESET ROLE;
+BEGIN;
+ROLLBACK;
+SELECT 'rollback_metadata', outdb_guc_can_read_metadata(rast)
+SELECT 'rollback_pixel', outdb_guc_can_read_pixel(rast)
+RESET ROLE;
+REVOKE SELECT ON raster_outdb_template FROM outdb_guc_regression_guest;
+REVOKE EXECUTE ON FUNCTION outdb_guc_can_read_metadata(raster) FROM outdb_guc_regression_guest;
+REVOKE EXECUTE ON FUNCTION outdb_guc_can_read_pixel(raster) FROM outdb_guc_regression_guest;
+DROP FUNCTION outdb_guc_can_read_metadata(raster);
+DROP FUNCTION outdb_guc_can_read_pixel(raster);
+DROP ROLE outdb_guc_regression_guest;
diff --git a/raster/test/regress/rt_outdb_guc_expected b/raster/test/regress/rt_outdb_guc_expected
index 000000000..dac34286f
--- /dev/null
+++ b/raster/test/regress/rt_outdb_guc_expected
@@ -0,0 +1,13 @@
+off
+off_metadata|f
+off_pixel|f
+off_indb_pixel|t
+on_metadata|t
+on_pixel|t
+off
+reset_metadata|f
+reset_pixel|f
+on
+off
+rollback_metadata|f
+rollback_pixel|f
diff --git a/raster/test/regress/tests.mk.in b/raster/test/regress/tests.mk.in
index 59fa11eab..eb614dcf7 100644
--- a/raster/test/regress/tests.mk.in
+++ b/raster/test/regress/tests.mk.in
@@ -22,7 +22,8 @@ override RUNTESTFLAGS_INTERNAL := \
 RASTER_TEST_FIRST = \
 	$(top_srcdir)/raster/test/regress/check_gdal \
-	$(top_srcdir)/raster/test/regress/loader/load_outdb
+	$(top_srcdir)/raster/test/regress/loader/load_outdb \
+	$(top_srcdir)/raster/test/regress/rt_outdb_guc
 RASTER_TEST_LAST = \
 	$(top_srcdir)/raster/test/regress/clean
Summary of changes:
 NEWS                                      |  4 ++
 raster/rt_pg/rtpostgis.c                  |  3 +-
 raster/test/regress/rt_outdb_guc.sql      | 88 +++++++++++++++++++++++++++++++
 raster/test/regress/rt_outdb_guc_expected | 13 +++++
 raster/test/regress/tests.mk.in           |  3 +-
 5 files changed, 109 insertions(+), 2 deletions(-)
 create mode 100644 raster/test/regress/rt_outdb_guc.sql
 create mode 100644 raster/test/regress/rt_outdb_guc_expected
hooks/post-receive
