[SCM] PostGIS branch stable-3.3 updated. 3.3.10-138-g4bfae5b54
Tue Sep 8 10:15:53 PDT 2026
the project "PostGIS".
The branch, stable-3.3 has been updated
       via  4bfae5b54cea43313c63e52252edb879be870ece (commit)
       via  ae8a57ac326ffb8efd8387e180933ea25812cbb3 (commit)
       via  904393f8c84fe043b6230f7008911420ee70867c (commit)
       via  46661b14dee6d32ab801b9f88df78823de56dbb7 (commit)
      from  6f7bf676d71179c4b3b3eab9cf492ab7a7380300 (commit)
revisions in full, below.
commit 4bfae5b54cea43313c63e52252edb879be870ece
Merge: 6f7bf676d ae8a57ac3
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Tue Sep 8 10:15:52 2026 -0700
    Merge pull request '[3.3] [raster] Enforce postgis.enable_outdb_rasters' (!785) from Komzpa/postgis:codex/backpatch-outdb-stable-33-20260907 into stable-3.3
    Bind postgis.enable_outdb_rasters to the core offline-band guard used by
    metadata and pixel reads. The documented default off setting now takes
    effect, while explicitly enabling out-db rasters preserves those reads.
    In-database rasters are unaffected.
    Also backport the existing GDAL build fix to use PostgreSQL's Min macro.
    References https://gitea.osgeo.org/postgis/postgis/pulls/779
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/785
commit ae8a57ac326ffb8efd8387e180933ea25812cbb3
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Mar 17 13:14:45 2026 -0700
    Fix CI failure in garden
    Cherry-picked-from: ab0fa8f3f46eda481a0195fd786932a0fba0e847
diff --git a/raster/rt_pg/rtpg_geometry.c b/raster/rt_pg/rtpg_geometry.c
index a4059a8bc..5bfd62ad9 100644
--- a/raster/rt_pg/rtpg_geometry.c
+++ b/raster/rt_pg/rtpg_geometry.c
@@ -1572,9 +1572,8 @@ Datum RASTER_asRaster(PG_FUNCTION_ARGS)
 		srs = NULL;
 	/* determine number of bands */
-	/* MIN macro is from GDAL's cpl_port.h */
-	num_bands = MIN(pixtypes_len, values_len);
-	num_bands = MIN(num_bands, nodatavals_len);
+	num_bands = Min(pixtypes_len, values_len);
+	num_bands = Min(num_bands, nodatavals_len);
 	POSTGIS_RT_DEBUGF(3, "RASTER_asRaster: pixtypes_len = %d", pixtypes_len);
 	POSTGIS_RT_DEBUGF(3, "RASTER_asRaster: values_len = %d", values_len);
 	POSTGIS_RT_DEBUGF(3, "RASTER_asRaster: nodatavals_len = %d", nodatavals_len);
commit 904393f8c84fe043b6230f7008911420ee70867c
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Tue Sep 8 01:24:28 2026 +0400
    NEWS: record GT-779 out-db GUC enforcement
diff --git a/NEWS b/NEWS
index 37c95baaa..cce344bc7 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,10 @@ PostGIS 3.3.11
 * Bug Fixes and Enhancements *
+ - GT-779, [raster] Make postgis.enable_outdb_rasters=off enforce offline-band
+   metadata and pixel-read restrictions after upgrade
+   (reported by Sarath Kumar, IITM Pravartak Security Team;
+   fixed by Darafei Praliaskouski)
  - GT-675, Preserve TRIANGLE children while normalizing malformed TINs
    (Darafei Praliaskouski)
  - #6038, Avoid stale geometry_columns relation lookups after relations are
commit 46661b14dee6d32ab801b9f88df78823de56dbb7
Date:   Mon Sep 7 23:25:33 2026 +0400
    Cherry-picked-from: a9634c0c735ae492efb3099d0cff0d26d0ce74be
diff --git a/raster/rt_pg/rtpostgis.c b/raster/rt_pg/rtpostgis.c
index 2fe1d18bf..ba028281d 100644
--- a/raster/rt_pg/rtpostgis.c
+++ b/raster/rt_pg/rtpostgis.c
@@ -454,7 +454,8 @@ static char *gdal_datapath = NULL;
 static char *gdal_vsi_options = NULL;
 static char *gdal_enabled_drivers = NULL;
-static bool enable_outdb_rasters = false;
+/* Defined in rt_band.c and used by the offline-band access guards. */
+extern bool enable_outdb_rasters;
 /*  Useful variables                                                */
@@ -823,4 +824,3 @@ _PG_fini(void) {
diff --git a/raster/test/regress/rt_outdb_guc.sql b/raster/test/regress/rt_outdb_guc.sql
new file mode 100644
index 000000000..1547c7d65
--- /dev/null
+++ b/raster/test/regress/rt_outdb_guc.sql
@@ -0,0 +1,88 @@
+CREATE FUNCTION outdb_guc_can_read_metadata(rast raster)
+RETURNS boolean
+AS $$
+BEGIN
+	PERFORM ST_BandFileSize(rast, 1);
+	RETURN true;
+EXCEPTION WHEN OTHERS THEN
+	RETURN false;
+END;
+$$ LANGUAGE plpgsql;
+CREATE FUNCTION outdb_guc_can_read_pixel(rast raster)
+RETURNS boolean
+AS $$
+BEGIN
+	PERFORM ST_Value(rast, 1, 1, 1);
+	RETURN true;
+	RETURN false;
+END;
+DO $$
+BEGIN
+	PERFORM postgis_raster_lib_version();
+END;
+CREATE ROLE outdb_guc_regression_guest;
+GRANT SELECT ON raster_outdb_template TO outdb_guc_regression_guest;
+GRANT EXECUTE ON FUNCTION outdb_guc_can_read_metadata(raster) TO outdb_guc_regression_guest;
+GRANT EXECUTE ON FUNCTION outdb_guc_can_read_pixel(raster) TO outdb_guc_regression_guest;
+SET postgis.gdal_enabled_drivers = 'GTiff';
+RESET postgis.enable_outdb_rasters;
+SHOW postgis.enable_outdb_rasters;
+SET ROLE outdb_guc_regression_guest;
+SELECT 'off_metadata', outdb_guc_can_read_metadata(rast)
+FROM raster_outdb_template WHERE rid = 1;
+SELECT 'off_pixel', outdb_guc_can_read_pixel(rast)
+SELECT 'off_indb_pixel', (
+	ST_Value(
+		ST_AddBand(
+			ST_MakeEmptyRaster(1, 1, 0, 0, 1, -1, 0, 0, 0),
+			1, '8BUI', 7, 0
+		1, 1, 1
+	) = 7
+RESET ROLE;
+SET postgis.enable_outdb_rasters = true;
+SELECT 'on_metadata', outdb_guc_can_read_metadata(rast)
+SELECT 'on_pixel', outdb_guc_can_read_pixel(rast)
+RESET ROLE;
+SELECT 'reset_metadata', outdb_guc_can_read_metadata(rast)
+SELECT 'reset_pixel', outdb_guc_can_read_pixel(rast)
+RESET ROLE;
+BEGIN;
+ROLLBACK;
+SELECT 'rollback_metadata', outdb_guc_can_read_metadata(rast)
+SELECT 'rollback_pixel', outdb_guc_can_read_pixel(rast)
+RESET ROLE;
+REVOKE SELECT ON raster_outdb_template FROM outdb_guc_regression_guest;
+REVOKE EXECUTE ON FUNCTION outdb_guc_can_read_metadata(raster) FROM outdb_guc_regression_guest;
+REVOKE EXECUTE ON FUNCTION outdb_guc_can_read_pixel(raster) FROM outdb_guc_regression_guest;
+DROP FUNCTION outdb_guc_can_read_metadata(raster);
+DROP FUNCTION outdb_guc_can_read_pixel(raster);
+DROP ROLE outdb_guc_regression_guest;
diff --git a/raster/test/regress/rt_outdb_guc_expected b/raster/test/regress/rt_outdb_guc_expected
index 000000000..dac34286f
--- /dev/null
+++ b/raster/test/regress/rt_outdb_guc_expected
@@ -0,0 +1,13 @@
+off
+off_metadata|f
+off_pixel|f
+off_indb_pixel|t
+on_metadata|t
+on_pixel|t
+off
+reset_metadata|f
+reset_pixel|f
+on
+off
+rollback_metadata|f
+rollback_pixel|f
diff --git a/raster/test/regress/tests.mk b/raster/test/regress/tests.mk
index 00918e134..71bd28f1e 100644
--- a/raster/test/regress/tests.mk
+++ b/raster/test/regress/tests.mk
@@ -19,7 +19,8 @@ override RUNTESTFLAGS_INTERNAL := \
 RASTER_TEST_FIRST = \
 	$(top_srcdir)/raster/test/regress/check_gdal \
-	$(top_srcdir)/raster/test/regress/loader/load_outdb
+	$(top_srcdir)/raster/test/regress/loader/load_outdb \
+	$(top_srcdir)/raster/test/regress/rt_outdb_guc
 RASTER_TEST_LAST = \
 	$(top_srcdir)/raster/test/regress/clean
Summary of changes:
 NEWS                                      |  4 ++
 raster/rt_pg/rtpg_geometry.c              |  5 +-
 raster/rt_pg/rtpostgis.c                  |  4 +-
 raster/test/regress/rt_outdb_guc.sql      | 88 +++++++++++++++++++++++++++++++
 raster/test/regress/rt_outdb_guc_expected | 13 +++++
 raster/test/regress/tests.mk              |  3 +-
 6 files changed, 111 insertions(+), 6 deletions(-)
 create mode 100644 raster/test/regress/rt_outdb_guc.sql
 create mode 100644 raster/test/regress/rt_outdb_guc_expected
hooks/post-receive
