[SCM] PostGIS branch stable-3.4 updated. 3.4.6-144-gc09db5548
Tue Sep 8 10:15:58 PDT 2026
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  c09db5548575f10591bfd228c427f68f819ca2d0 (commit)
       via  25fa1fe590be3a212f8cbadf0183f574c85c20eb (commit)
       via  17e25ed29ee9e04c2952e23c2140033f28c10035 (commit)
      from  58adc259c3c9c819a890d0a7a93ab4c582d9c70b (commit)
revisions in full, below.
commit c09db5548575f10591bfd228c427f68f819ca2d0
Merge: 58adc259c 25fa1fe59
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Tue Sep 8 10:15:57 2026 -0700
    Merge pull request '[3.4] [raster] Enforce postgis.enable_outdb_rasters' (!786) from Komzpa/postgis:codex/backpatch-outdb-stable-34-20260907 into stable-3.4
    Bind postgis.enable_outdb_rasters to the core offline-band guard used by
    metadata and pixel reads. The documented default off setting now takes
    effect, while explicitly enabling out-db rasters preserves those reads.
    In-database rasters are unaffected.
    References https://gitea.osgeo.org/postgis/postgis/pulls/779
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/786
commit 25fa1fe590be3a212f8cbadf0183f574c85c20eb
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Tue Sep 8 01:24:28 2026 +0400
    NEWS: record GT-779 out-db GUC enforcement
diff --git a/NEWS b/NEWS
index 9a8191ad3..cae28b31c 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,10 @@ PostGIS 3.4.7
 * Bug Fixes *
+  - GT-779, [raster] Make postgis.enable_outdb_rasters=off enforce offline-band
+    metadata and pixel-read restrictions after upgrade
+    (reported by Sarath Kumar, IITM Pravartak Security Team;
+    fixed by Darafei Praliaskouski)
   - GT-675, Preserve TRIANGLE children while normalizing malformed TINs
     (Darafei Praliaskouski)
   - #6038, Avoid stale geometry_columns relation lookups after relations are
commit 17e25ed29ee9e04c2952e23c2140033f28c10035
Date:   Mon Sep 7 23:25:33 2026 +0400
    Cherry-picked-from: a9634c0c735ae492efb3099d0cff0d26d0ce74be
diff --git a/raster/rt_pg/rtpostgis.c b/raster/rt_pg/rtpostgis.c
index 44af11c79..f2e89c071 100644
--- a/raster/rt_pg/rtpostgis.c
+++ b/raster/rt_pg/rtpostgis.c
@@ -461,7 +461,8 @@ rt_pg_vsi_check_options(char **newval, void **extra, GucSource source)
 static char *gdal_datapath = NULL;
 static char *gdal_vsi_options = NULL;
 static char *gdal_enabled_drivers = NULL;
-static bool enable_outdb_rasters = false;
+/* Defined in rt_band.c and used by the offline-band access guards. */
+extern bool enable_outdb_rasters;
 /*  Useful variables                                                */
@@ -830,4 +831,3 @@ _PG_fini(void) {
diff --git a/raster/test/regress/rt_outdb_guc.sql b/raster/test/regress/rt_outdb_guc.sql
new file mode 100644
index 000000000..1547c7d65
--- /dev/null
+++ b/raster/test/regress/rt_outdb_guc.sql
@@ -0,0 +1,88 @@
+CREATE FUNCTION outdb_guc_can_read_metadata(rast raster)
+RETURNS boolean
+AS $$
+BEGIN
+	PERFORM ST_BandFileSize(rast, 1);
+	RETURN true;
+EXCEPTION WHEN OTHERS THEN
+	RETURN false;
+END;
+$$ LANGUAGE plpgsql;
+CREATE FUNCTION outdb_guc_can_read_pixel(rast raster)
+RETURNS boolean
+AS $$
+BEGIN
+	PERFORM ST_Value(rast, 1, 1, 1);
+	RETURN true;
+	RETURN false;
+END;
+DO $$
+BEGIN
+	PERFORM postgis_raster_lib_version();
+END;
+CREATE ROLE outdb_guc_regression_guest;
+GRANT SELECT ON raster_outdb_template TO outdb_guc_regression_guest;
+GRANT EXECUTE ON FUNCTION outdb_guc_can_read_metadata(raster) TO outdb_guc_regression_guest;
+GRANT EXECUTE ON FUNCTION outdb_guc_can_read_pixel(raster) TO outdb_guc_regression_guest;
+SET postgis.gdal_enabled_drivers = 'GTiff';
+RESET postgis.enable_outdb_rasters;
+SHOW postgis.enable_outdb_rasters;
+SET ROLE outdb_guc_regression_guest;
+SELECT 'off_metadata', outdb_guc_can_read_metadata(rast)
+FROM raster_outdb_template WHERE rid = 1;
+SELECT 'off_pixel', outdb_guc_can_read_pixel(rast)
+SELECT 'off_indb_pixel', (
+	ST_Value(
+		ST_AddBand(
+			ST_MakeEmptyRaster(1, 1, 0, 0, 1, -1, 0, 0, 0),
+			1, '8BUI', 7, 0
+		1, 1, 1
+	) = 7
+RESET ROLE;
+SET postgis.enable_outdb_rasters = true;
+SELECT 'on_metadata', outdb_guc_can_read_metadata(rast)
+SELECT 'on_pixel', outdb_guc_can_read_pixel(rast)
+RESET ROLE;
+SELECT 'reset_metadata', outdb_guc_can_read_metadata(rast)
+SELECT 'reset_pixel', outdb_guc_can_read_pixel(rast)
+RESET ROLE;
+BEGIN;
+ROLLBACK;
+SELECT 'rollback_metadata', outdb_guc_can_read_metadata(rast)
+SELECT 'rollback_pixel', outdb_guc_can_read_pixel(rast)
+RESET ROLE;
+REVOKE SELECT ON raster_outdb_template FROM outdb_guc_regression_guest;
+REVOKE EXECUTE ON FUNCTION outdb_guc_can_read_metadata(raster) FROM outdb_guc_regression_guest;
+REVOKE EXECUTE ON FUNCTION outdb_guc_can_read_pixel(raster) FROM outdb_guc_regression_guest;
+DROP FUNCTION outdb_guc_can_read_metadata(raster);
+DROP FUNCTION outdb_guc_can_read_pixel(raster);
+DROP ROLE outdb_guc_regression_guest;
diff --git a/raster/test/regress/rt_outdb_guc_expected b/raster/test/regress/rt_outdb_guc_expected
index 000000000..dac34286f
--- /dev/null
+++ b/raster/test/regress/rt_outdb_guc_expected
@@ -0,0 +1,13 @@
+off
+off_metadata|f
+off_pixel|f
+off_indb_pixel|t
+on_metadata|t
+on_pixel|t
+off
+reset_metadata|f
+reset_pixel|f
+on
+off
+rollback_metadata|f
+rollback_pixel|f
diff --git a/raster/test/regress/tests.mk b/raster/test/regress/tests.mk
index 00918e134..71bd28f1e 100644
--- a/raster/test/regress/tests.mk
+++ b/raster/test/regress/tests.mk
@@ -19,7 +19,8 @@ override RUNTESTFLAGS_INTERNAL := \
 RASTER_TEST_FIRST = \
 	$(top_srcdir)/raster/test/regress/check_gdal \
-	$(top_srcdir)/raster/test/regress/loader/load_outdb
+	$(top_srcdir)/raster/test/regress/loader/load_outdb \
+	$(top_srcdir)/raster/test/regress/rt_outdb_guc
 RASTER_TEST_LAST = \
 	$(top_srcdir)/raster/test/regress/clean
Summary of changes:
 NEWS                                      |  4 ++
 raster/rt_pg/rtpostgis.c                  |  4 +-
 raster/test/regress/rt_outdb_guc.sql      | 88 +++++++++++++++++++++++++++++++
 raster/test/regress/rt_outdb_guc_expected | 13 +++++
 raster/test/regress/tests.mk              |  3 +-
 5 files changed, 109 insertions(+), 3 deletions(-)
 create mode 100644 raster/test/regress/rt_outdb_guc.sql
 create mode 100644 raster/test/regress/rt_outdb_guc_expected
hooks/post-receive
