[SCM] PostGIS branch stable-3.5 updated. 3.5.7-144-g26d270d4b
git at osgeo.org
git at osgeo.org
Tue Sep 8 10:16:05 PDT 2026
the project "PostGIS".
The branch, stable-3.5 has been updated
via 26d270d4b9436ce91d032b050a33c9627ec0fe3f (commit)
via 673edfbce634936ee826ad74f3c6116b228066e2 (commit)
via 60a296cc85caa89e0e6335bfa8e58ca80300a72a (commit)
from f0cdc854901ea6f02ec81dcb751f1355e3739af7 (commit)
revisions in full, below.
commit 26d270d4b9436ce91d032b050a33c9627ec0fe3f
Merge: f0cdc8549 673edfbce
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Tue Sep 8 10:16:04 2026 -0700
Merge pull request '[3.5] [raster] Enforce postgis.enable_outdb_rasters' (!787) from Komzpa/postgis:codex/backpatch-outdb-stable-35-20260907 into stable-3.5
Bind postgis.enable_outdb_rasters to the core offline-band guard used by
metadata and pixel reads. The documented default off setting now takes
effect, while explicitly enabling out-db rasters preserves those reads.
In-database rasters are unaffected.
References https://gitea.osgeo.org/postgis/postgis/pulls/779
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/787
commit 673edfbce634936ee826ad74f3c6116b228066e2
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Tue Sep 8 01:24:28 2026 +0400
NEWS: record GT-779 out-db GUC enforcement
diff --git a/NEWS b/NEWS
index 8cd60959a..b044ef9be 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,10 @@ PostGIS 3.5.8dev
* Bug Fixes *
+ - GT-779, [raster] Make postgis.enable_outdb_rasters=off enforce offline-band
+ metadata and pixel-read restrictions after upgrade
+ (reported by Sarath Kumar, IITM Pravartak Security Team;
+ fixed by Darafei Praliaskouski)
- #6120, Improve topology robustness by restoring edge collapse handling
during building (Sandro Santilli)
- GT-675, Preserve TRIANGLE children while normalizing malformed TINs
commit 60a296cc85caa89e0e6335bfa8e58ca80300a72a
Date: Mon Sep 7 23:25:33 2026 +0400
Cherry-picked-from: a9634c0c735ae492efb3099d0cff0d26d0ce74be
diff --git a/raster/rt_pg/rtpostgis.c b/raster/rt_pg/rtpostgis.c
index 0ec8b1d6c..bd03b04ef 100644
--- a/raster/rt_pg/rtpostgis.c
+++ b/raster/rt_pg/rtpostgis.c
@@ -461,7 +461,8 @@ rt_pg_vsi_check_options(char **newval, void **extra, GucSource source)
static char *gdal_datapath = NULL;
static char *gdal_vsi_options = NULL;
static char *gdal_enabled_drivers = NULL;
-static bool enable_outdb_rasters = false;
+/* Defined in rt_band.c and used by the offline-band access guards. */
+extern bool enable_outdb_rasters;
/* Useful variables */
@@ -830,4 +831,3 @@ _PG_fini(void) {
diff --git a/raster/test/regress/rt_outdb_guc.sql b/raster/test/regress/rt_outdb_guc.sql
new file mode 100644
index 000000000..1547c7d65
--- /dev/null
+++ b/raster/test/regress/rt_outdb_guc.sql
@@ -0,0 +1,88 @@
+CREATE FUNCTION outdb_guc_can_read_metadata(rast raster)
+RETURNS boolean
+AS $$
+BEGIN
+ PERFORM ST_BandFileSize(rast, 1);
+ RETURN true;
+EXCEPTION WHEN OTHERS THEN
+ RETURN false;
+END;
+$$ LANGUAGE plpgsql;
+CREATE FUNCTION outdb_guc_can_read_pixel(rast raster)
+RETURNS boolean
+AS $$
+BEGIN
+ PERFORM ST_Value(rast, 1, 1, 1);
+ RETURN true;
+ RETURN false;
+END;
+DO $$
+BEGIN
+ PERFORM postgis_raster_lib_version();
+END;
+CREATE ROLE outdb_guc_regression_guest;
+GRANT SELECT ON raster_outdb_template TO outdb_guc_regression_guest;
+GRANT EXECUTE ON FUNCTION outdb_guc_can_read_metadata(raster) TO outdb_guc_regression_guest;
+GRANT EXECUTE ON FUNCTION outdb_guc_can_read_pixel(raster) TO outdb_guc_regression_guest;
+SET postgis.gdal_enabled_drivers = 'GTiff';
+RESET postgis.enable_outdb_rasters;
+SHOW postgis.enable_outdb_rasters;
+SET ROLE outdb_guc_regression_guest;
+SELECT 'off_metadata', outdb_guc_can_read_metadata(rast)
+FROM raster_outdb_template WHERE rid = 1;
+SELECT 'off_pixel', outdb_guc_can_read_pixel(rast)
+SELECT 'off_indb_pixel', (
+ ST_Value(
+ ST_AddBand(
+ ST_MakeEmptyRaster(1, 1, 0, 0, 1, -1, 0, 0, 0),
+ 1, '8BUI', 7, 0
+ 1, 1, 1
+ ) = 7
+RESET ROLE;
+SET postgis.enable_outdb_rasters = true;
+SELECT 'on_metadata', outdb_guc_can_read_metadata(rast)
+SELECT 'on_pixel', outdb_guc_can_read_pixel(rast)
+RESET ROLE;
+SELECT 'reset_metadata', outdb_guc_can_read_metadata(rast)
+SELECT 'reset_pixel', outdb_guc_can_read_pixel(rast)
+RESET ROLE;
+BEGIN;
+ROLLBACK;
+SELECT 'rollback_metadata', outdb_guc_can_read_metadata(rast)
+SELECT 'rollback_pixel', outdb_guc_can_read_pixel(rast)
+RESET ROLE;
+REVOKE SELECT ON raster_outdb_template FROM outdb_guc_regression_guest;
+REVOKE EXECUTE ON FUNCTION outdb_guc_can_read_metadata(raster) FROM outdb_guc_regression_guest;
+REVOKE EXECUTE ON FUNCTION outdb_guc_can_read_pixel(raster) FROM outdb_guc_regression_guest;
+DROP FUNCTION outdb_guc_can_read_metadata(raster);
+DROP FUNCTION outdb_guc_can_read_pixel(raster);
+DROP ROLE outdb_guc_regression_guest;
diff --git a/raster/test/regress/rt_outdb_guc_expected b/raster/test/regress/rt_outdb_guc_expected
index 000000000..dac34286f
--- /dev/null
+++ b/raster/test/regress/rt_outdb_guc_expected
@@ -0,0 +1,13 @@
+off
+off_metadata|f
+off_pixel|f
+off_indb_pixel|t
+on_metadata|t
+on_pixel|t
+off
+reset_metadata|f
+reset_pixel|f
+on
+off
+rollback_metadata|f
+rollback_pixel|f
diff --git a/raster/test/regress/tests.mk b/raster/test/regress/tests.mk
index 00918e134..71bd28f1e 100644
--- a/raster/test/regress/tests.mk
+++ b/raster/test/regress/tests.mk
@@ -19,7 +19,8 @@ override RUNTESTFLAGS_INTERNAL := \
RASTER_TEST_FIRST = \
$(top_srcdir)/raster/test/regress/check_gdal \
- $(top_srcdir)/raster/test/regress/loader/load_outdb
+ $(top_srcdir)/raster/test/regress/loader/load_outdb \
+ $(top_srcdir)/raster/test/regress/rt_outdb_guc
RASTER_TEST_LAST = \
$(top_srcdir)/raster/test/regress/clean
Summary of changes:
NEWS | 4 ++
raster/rt_pg/rtpostgis.c | 4 +-
raster/test/regress/rt_outdb_guc.sql | 88 +++++++++++++++++++++++++++++++
raster/test/regress/rt_outdb_guc_expected | 13 +++++
raster/test/regress/tests.mk | 3 +-
5 files changed, 109 insertions(+), 3 deletions(-)
create mode 100644 raster/test/regress/rt_outdb_guc.sql
create mode 100644 raster/test/regress/rt_outdb_guc_expected
hooks/post-receive
