[SCM] PostGIS branch stable-3.6 updated. 3.6.4-145-g078722e0b
Tue Sep 8 10:16:13 PDT 2026
the project "PostGIS".
The branch, stable-3.6 has been updated
       via  078722e0b17d6c4d1b5d21531da614cc0b6d193a (commit)
       via  b7a7e3caac85e3c35bb70973371f858a1e9272b7 (commit)
       via  5cae8626ed12c2acd3b2a706e12a487a6f974974 (commit)
      from  effa73b6fe547c182f66b9f143029a20db4acaf0 (commit)
revisions in full, below.
commit 078722e0b17d6c4d1b5d21531da614cc0b6d193a
Merge: effa73b6f b7a7e3caa
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Tue Sep 8 10:16:12 2026 -0700
    Merge pull request '[3.6] [raster] Enforce postgis.enable_outdb_rasters' (!788) from Komzpa/postgis:codex/backpatch-outdb-stable-36-20260907 into stable-3.6
    Bind postgis.enable_outdb_rasters to the core offline-band guard used by
    metadata and pixel reads. The documented default off setting now takes
    effect, while explicitly enabling out-db rasters preserves those reads.
    In-database rasters are unaffected.
    References https://gitea.osgeo.org/postgis/postgis/pulls/779
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/788
commit b7a7e3caac85e3c35bb70973371f858a1e9272b7
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Tue Sep 8 01:24:28 2026 +0400
    NEWS: record GT-779 out-db GUC enforcement
diff --git a/NEWS b/NEWS
index 727d61763..ff187ea36 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,10 @@ PostGIS 3.6.5dev
 * Fixes *
+- GT-779, [raster] Make postgis.enable_outdb_rasters=off enforce offline-band
+  metadata and pixel-read restrictions after upgrade
+  (reported by Sarath Kumar, IITM Pravartak Security Team;
+  fixed by Darafei Praliaskouski)
 - #6120, Improve topology robustness by restoring edge collapse handling
          during building (Sandro Santilli)
 - GT-675, Preserve TRIANGLE children while normalizing malformed TINs
commit 5cae8626ed12c2acd3b2a706e12a487a6f974974
Date:   Mon Sep 7 23:25:33 2026 +0400
    Cherry-picked-from: a9634c0c735ae492efb3099d0cff0d26d0ce74be
diff --git a/raster/rt_pg/rtpostgis.c b/raster/rt_pg/rtpostgis.c
index 228717f36..33e766b17 100644
--- a/raster/rt_pg/rtpostgis.c
+++ b/raster/rt_pg/rtpostgis.c
@@ -460,7 +460,8 @@ rt_pg_vsi_check_options(char **newval, void **extra, GucSource source)
 static char *gdal_datapath = NULL;
 static char *gdal_vsi_options = NULL;
 static char *gdal_enabled_drivers = NULL;
-static bool enable_outdb_rasters = false;
+/* Defined in rt_band.c and used by the offline-band access guards. */
+extern bool enable_outdb_rasters;
 static bool gdal_cpl_debug = false;
diff --git a/raster/test/regress/rt_outdb_guc.sql b/raster/test/regress/rt_outdb_guc.sql
new file mode 100644
index 000000000..1547c7d65
--- /dev/null
+++ b/raster/test/regress/rt_outdb_guc.sql
@@ -0,0 +1,88 @@
+CREATE FUNCTION outdb_guc_can_read_metadata(rast raster)
+RETURNS boolean
+AS $$
+BEGIN
+	PERFORM ST_BandFileSize(rast, 1);
+	RETURN true;
+EXCEPTION WHEN OTHERS THEN
+	RETURN false;
+END;
+$$ LANGUAGE plpgsql;
+CREATE FUNCTION outdb_guc_can_read_pixel(rast raster)
+RETURNS boolean
+AS $$
+BEGIN
+	PERFORM ST_Value(rast, 1, 1, 1);
+	RETURN true;
+	RETURN false;
+END;
+DO $$
+BEGIN
+	PERFORM postgis_raster_lib_version();
+END;
+CREATE ROLE outdb_guc_regression_guest;
+GRANT SELECT ON raster_outdb_template TO outdb_guc_regression_guest;
+GRANT EXECUTE ON FUNCTION outdb_guc_can_read_metadata(raster) TO outdb_guc_regression_guest;
+GRANT EXECUTE ON FUNCTION outdb_guc_can_read_pixel(raster) TO outdb_guc_regression_guest;
+SET postgis.gdal_enabled_drivers = 'GTiff';
+RESET postgis.enable_outdb_rasters;
+SHOW postgis.enable_outdb_rasters;
+SET ROLE outdb_guc_regression_guest;
+SELECT 'off_metadata', outdb_guc_can_read_metadata(rast)
+FROM raster_outdb_template WHERE rid = 1;
+SELECT 'off_pixel', outdb_guc_can_read_pixel(rast)
+SELECT 'off_indb_pixel', (
+	ST_Value(
+		ST_AddBand(
+			ST_MakeEmptyRaster(1, 1, 0, 0, 1, -1, 0, 0, 0),
+			1, '8BUI', 7, 0
+		1, 1, 1
+	) = 7
+RESET ROLE;
+SET postgis.enable_outdb_rasters = true;
+SELECT 'on_metadata', outdb_guc_can_read_metadata(rast)
+SELECT 'on_pixel', outdb_guc_can_read_pixel(rast)
+RESET ROLE;
+SELECT 'reset_metadata', outdb_guc_can_read_metadata(rast)
+SELECT 'reset_pixel', outdb_guc_can_read_pixel(rast)
+RESET ROLE;
+BEGIN;
+ROLLBACK;
+SELECT 'rollback_metadata', outdb_guc_can_read_metadata(rast)
+SELECT 'rollback_pixel', outdb_guc_can_read_pixel(rast)
+RESET ROLE;
+REVOKE SELECT ON raster_outdb_template FROM outdb_guc_regression_guest;
+REVOKE EXECUTE ON FUNCTION outdb_guc_can_read_metadata(raster) FROM outdb_guc_regression_guest;
+REVOKE EXECUTE ON FUNCTION outdb_guc_can_read_pixel(raster) FROM outdb_guc_regression_guest;
+DROP FUNCTION outdb_guc_can_read_metadata(raster);
+DROP FUNCTION outdb_guc_can_read_pixel(raster);
+DROP ROLE outdb_guc_regression_guest;
diff --git a/raster/test/regress/rt_outdb_guc_expected b/raster/test/regress/rt_outdb_guc_expected
index 000000000..dac34286f
--- /dev/null
+++ b/raster/test/regress/rt_outdb_guc_expected
@@ -0,0 +1,13 @@
+off
+off_metadata|f
+off_pixel|f
+off_indb_pixel|t
+on_metadata|t
+on_pixel|t
+off
+reset_metadata|f
+reset_pixel|f
+on
+off
+rollback_metadata|f
+rollback_pixel|f
diff --git a/raster/test/regress/tests.mk.in b/raster/test/regress/tests.mk.in
index 111be04e7..ab502d67a 100644
--- a/raster/test/regress/tests.mk.in
+++ b/raster/test/regress/tests.mk.in
@@ -21,7 +21,8 @@ override RUNTESTFLAGS_INTERNAL := \
 RASTER_TEST_FIRST = \
 	$(top_srcdir)/raster/test/regress/check_gdal \
-	$(top_srcdir)/raster/test/regress/loader/load_outdb
+	$(top_srcdir)/raster/test/regress/loader/load_outdb \
+	$(top_srcdir)/raster/test/regress/rt_outdb_guc
 RASTER_TEST_LAST = \
 	$(top_srcdir)/raster/test/regress/clean
Summary of changes:
 NEWS                                      |  4 ++
 raster/rt_pg/rtpostgis.c                  |  3 +-
 raster/test/regress/rt_outdb_guc.sql      | 88 +++++++++++++++++++++++++++++++
 raster/test/regress/rt_outdb_guc_expected | 13 +++++
 raster/test/regress/tests.mk.in           |  3 +-
 5 files changed, 109 insertions(+), 2 deletions(-)
 create mode 100644 raster/test/regress/rt_outdb_guc.sql
 create mode 100644 raster/test/regress/rt_outdb_guc_expected
hooks/post-receive
