[PostGIS] #6133: Geography line interpolation: NaN heading along a meridian, wrong meridian past a pole, uninitialised Z and M
trac at osgeo.org
Mon Sep 14 05:34:37 PDT 2026
Reporter: ezimanyi | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS
| 3.6.5
Component: postgis | Version: 3.6.x
Keywords: geography ST_LineInterpolatePoint |
ST_LineInterpolatePoints sphere_direction |
sphere_project |
The interpolation of geography lines, which came with #5460, goes
through `interpolate_point4d_spheroid()` in
`liblwgeom/lwgeodetic_measures.c` and, on the sphere, through
`sphere_direction()` and `sphere_project()` in `liblwgeom/lwgeodetic.c`.
Each of the three has a defect of its own. All three reproduce on
PostGIS 3.6.3, and master 2bb71185a8 carries the same code.
== 1. sphere_direction() returns NaN for two points on one meridian ==
`sphere_direction()` computes the initial heading from its cosine,
f = (sin(lat2) - sin(lat1) * cos(d)) / (sin(d) * cos(lat1))
heading = acos(f)
For two points on one meridian the exact value of `f` is 1 or -1, and
rounding leaves it outside [-1, 1] by more than `FP_TOLERANCE` (5e-14
for the geodetic code), so `acos()` returns NaN; the `fabs(f) > 1.0`
branch logs the value and still calls `acos()`. Over 43800 segments
along the prime meridian between 80S and 80N, up to 0.02 degrees long,
these expressions give NaN for 17791 of them. `sphere_project()` then
fails, and (see 3) the result is the caller's uninitialised point:
{{{#!sql
SELECT ST_AsText(ST_LineInterpolatePoint(
'LINESTRING(0 -79.269, 0 -79.239)'::geography, 0.5, false));
-- POINT(6.95314402316196e-310 6.9229486544248e-310)
'LINESTRING(0 -79.269, 0 -79.239)'::geography, 0.5, true));
-- POINT(0 -79.25400000727056)
The circular tree already guards against the NaN:
`circ_center_spherical()` in `lwgeodetic_tree.c` tests the heading
with `isnan()` ("Catch sphere_direction when it barfs") and falls back
to a Cartesian centre.
== 2. sphere_project() keeps the start meridian past a pole ==
For an azimuth of 0 or pi, `sphere_project()` keeps the start
longitude, which holds up to the pole and not beyond it; the source
marks it with "TODO: this isn't quite true, what if we're going over
the pole?". Past the pole the path runs down the opposite meridian:
{{{#!sql
'LINESTRING(0 88, 180 88)'::geography, 0.75, false));
-- POINT(0 89.0000000000001)
'LINESTRING(0 88, 180 88)'::geography, 0.75, true));
-- POINT(180 89.00000307849999)
== 3. interpolate_point4d_spheroid() leaves Z, M, and a failed x and y
uninitialised ==
The function sets only x and y, and only when the projection succeeds:
/* If success, use newly computed lat and lon,
* otherwise return precomputed cartesian result */
if (success == LW_SUCCESS)
p->x = rad2deg(longitude_radians_normalize(g.lon));
p->y = rad2deg(latitude_radians_normalize(g.lat));
Nothing precomputes the Cartesian result the comment names, and both
callers, `geography_substring()` and `geography_interpolate_points()`,
pass an uninitialised `POINT4D pt`. So every interpolated Z and M is
whatever the stack held, on the sphere and on the spheroid alike:
{{{#!sql
'LINESTRING Z(0 0 0, 10 0 10)'::geography, 0.5, true));
-- POINT Z (5.000000000201743 0 6.95291892163796e-310)
'LINESTRING Z(0 0 0, 10 0 10)'::geography, 0.5, false));
-- POINT Z (5.000000000202194 3.057732552914371e-16 5.0170810976182e-310)
The function comes from MobilityDB (#5460), whose version, now in
`meos/src/geo/tpoint_spatialfuncs.c`, calls `interpolate_point4d(p1,
p2, p, f)` before the success test; that call is absent from the
PostGIS version.
== Fix ==
1. `sphere_direction()` reads the heading with `atan2()` from both
components of the initial bearing,
heading = atan2(sin(dlon) * cos(lat2),
cos(lat1) * sin(lat2) - sin(lat1) * cos(lat2) * cos(dlon))
The sine and cosine of the heading are these two components
divided by sin(d) > 0, so this is the heading wherever the two
points are distinct, with no cosine to leave its range and no
clamp. It answers exactly 0 or pi along a meridian and keeps the
sign convention. The distance argument is no longer read and stays
in the signature.
2. `sphere_project()` keeps its shortcut and answers the opposite
meridian past the pole,
lon2 = ( cos(d) - sin(lat1) * sin(lat2) < 0.0 ) ? lon1 + M_PI : lon1;
`cos(d) - sin(lat1) * sin(lat2)` is the second component of the
general formula below the shortcut and equals `cos(lat1) *
cos(lat2) * cos(dlon)`, so along a meridian its sign is that of
`cos(dlon)`: positive on the start meridian, negative on the
opposite one. The TODO goes.
3. `interpolate_point4d_spheroid()` computes the Cartesian
interpolation first, which also interpolates z and m, and a
successful projection overwrites x and y.
== Tests ==
The patch adds to `liblwgeom/cunit/cu_geodetic.c` the meridian pair
(0 -79.269) and (0 -79.239) in both directions to
`test_sphere_direction()`, expecting 0 and pi, and a projection due
north from 88N over 3 degrees to `test_sphere_project()`, expecting 89N
on the opposite meridian. It adds to `regress/core/geography.sql` the
cases `lrs_lip_pole_sphere`, `lrs_lip_meridian_sphere`, `lrs_lip_z` and
`lrs_lip_zm`.
Measured on master 2bb71185a8 with PostgreSQL 18.3 and CUnit 2.1-3:
* with the patch, the cunit geodetic suite passes 25 of 25 tests and
536 of 536 assertions, and every suite 375 tests and 5901
assertions, none failing;
* with the new tests but without the fixes in `lwgeodetic.c` and
`lwgeodetic_measures.c`, the geodetic suite fails 2 of 25 tests and
3 of 536 assertions, exactly the new ones: `cu_geodetic.c:96` and
`:98` (the heading along the meridian, NaN) and `:185` (the
longitude past the pole, 0 instead of pi);
* with the patch, `regress/core/geography` passes under
`run_test.pl --extension`, the four new cases answering
`POINT(180 89)`, `POINT(0 -79.254)`, `POINT Z (5 0 5)` and
`MULTIPOINT ZM ((5 0 5 10),(10 0 10 20))`.
These were found while fixing the same functions in the copy of
liblwgeom that MobilityDB vendors:
[https://github.com/MobilityDB/MobilityDB/pull/2722 MobilityDB#2722]
(the heading) and
[https://github.com/MobilityDB/MobilityDB/pull/2720 MobilityDB#2720]
(the pole).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6133>
