[PostGIS] #6113: 3.7.0beta2 visual examples build error
trac at osgeo.org
Fri Sep 25 07:57:04 PDT 2026
Reporter: gdt | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.7.0
Component: postgis | Version: master
Resolution: | Keywords:
Old description:
> Building 3.7.0beta2 under pkgsrc, it fails with a check about "visual
> examples" and a warning to build with a regress makefile. At this point
> pkgsrc is only building, not building/running tests.
> gmake[1]: Entering directory '/tmp/work/databases/postgresql-
> postgis2/work/postgis-3.7.0beta2'
> /usr/pkg/bin/perl ./utils/repo_revision.pl
> fatal: not a git repository (or any parent up to mount point /)
> Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not
> set).
> Can't determine revision from git log
> Not updating existing rev file at 6e55c62
> /tmp/work/databases/postgresql-postgis2/work/.tools/bin/gmake -C doc html
> gmake[2]: Entering directory '/tmp/work/databases/postgresql-
> postgis2/work/postgis-3.7.0beta2/doc'
> /usr/pkg/bin/perl -pe "s!\@\@XSLBASE\@\@!/usr/pkg/share/xsl/docbook!g;
> s!\@\@ABS_SRCDIR\@\@!/tmp/work/databases/postgresql-
> postgis2/work/postgis-3.7.0beta2/doc!g;" /tmp/work/databases/postgresql-
> postgis2/work/postgis-3.7.0beta2/doc/xsl/postgis-html.xsl.in > postgis-
> html.xsl
> mkdir -p /tmp/work/databases/postgresql-
> postgis2/work/postgis-3.7.0beta2/doc/html
> /usr/pkg/bin/python3 /tmp/work/databases/postgresql-
> postgis2/work/postgis-3.7.0beta2/utils/docs/docbook_qa.py ref-index
> postgis-out.xml /tmp/work/databases/postgresql-
> postgis2/work/postgis-3.7.0beta2/doc/html/postgis-ref-index.json
> wrote /tmp/work/databases/postgresql-
> postgis2/work/postgis-3.7.0beta2/doc/html/postgis-ref-index.json and
> /tmp/work/databases/postgresql-postgis2/work/postgis-3.7.0beta2/doc/html
> /postgis-ref-index.js; commands=1, functions=630, operator pages=37, SQL
> keywords=63
> postgis2/work/postgis-3.7.0beta2/doc/html/images visual-examples-check
> gmake[3]: Entering directory '/tmp/work/databases/postgresql-
> postgis2/work/postgis-3.7.0beta2/doc/html/images'
> Visual examples are missing. Run 'make -C regress visual-examples' first.
> gmake[3]: *** [Makefile:52: visual-examples-check] Error 1
New description:
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
html.xsl
keywords=63
Comment (by strk):
I'm seeing the same behavior, but worse I'm also unable to build those
visual examples (which is matter for a new ticket)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6113#comment:2>
