[PostGIS] #6134: visual examples can't be built if sfcgal is not enabled
trac at osgeo.org
Sat Sep 26 21:39:08 PDT 2026
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.7.0
Component: build | Version: master
Resolution: | Keywords:
Comment (by robe):
Should we disable docs for sections where you don't build e.g. if sfcgal
is not enabled makes sense you wouldn't need sfcgal docs right?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6134#comment:1>
