[PostGIS] #6134: visual examples can't be built if sfcgal is not enabled
trac at osgeo.org
Mon Sep 28 05:52:45 PDT 2026
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.7.0
Component: build | Version: master
Resolution: | Keywords:
Comment (by robe):
Working on the patch for this. I think it is still worthwhile to build
docs but just disable the visual examples and remove those from doc output
and also the same for garden tests.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6134#comment:2>
