[postgis] Problem with installation PostGis
TONY J.Y.
tjiang at mrf.com
Fri Dec 7 07:17:14 PST 2001
Yes. it is. You should have the compiled source ready before you
want to install the postGIS.
Download the source of posgreSQL and make it first, then copy
postGIS to its contrib, make it. Then make install all.
----- Original Message -----
From: "silvio buffa" <torodedutoesdraiato at yahoo.it>
To: <postgis at yahoogroups.com>
Sent: Friday, December 07, 2001 3:31 AM
Subject: [postgis] Problem with installation PostGis
> I have installeted before PostgreSQL 7.1.3 using the
> RPM for Red Hat, after I try to installation of
> Postgis, but following the instruction of installation
> of chapter 2 of Postgis I have problem because the
> procedure not work good, perhaps because in the
> directory contrib using rpm of PostgreSQL not contains
> the source code di PostGreSQL.
> What do I do?
> ____________________________________________________________
> Nokia 5510 insolito ma geniale.
> Vai a http://it.promotions.yahoo.com/nokia/
> scoprilo e vincilo. Il concorso termina il 16 dicembre 2001.
> To unsubscribe from this group, send an email to:
> postgis-unsubscribe at yahoogroups.com
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Quit now for Great
American Smokeout
http://us.click.yahoo.com/0vN8tD/9pSDAA/ySSFAA/PhFolB/TM
