[postgis] Why is there the limitation of PGLIB to get the cursor?
TONY J.Y.
tjiang at mrf.com
Fri Dec 7 08:08:38 PST 2001
Dave,
I went to the linux server where the database was located. Ran the
psql session to declare
the big cursor and fetch all in the cursor. there was no error
there. I could declare the cursor,
and fetched all rows from the cursor. So PostgreSQL server-side
is OK. The asbinary function
is OK too.
I ran my program at client side (Win2K Pro with libpq). There
came the error message when the
geom data is bigger:
"char *PQerrorMessage(const PGconn* conn);"
Error = pqReadData() -- read() failed: errno=0
So there is some limit in the pqReadData() -- read() of the C
library libpq, isn't there?
../Tony
----- Original Message -----
To: <postgis at yahoogroups.com>
Sent: Thursday, December 06, 2001 10:42 AM
Subject: Re: [postgis] Why is there the limitation of PGLIB to get the
cursor?
> Tony,
> I looked at your code and it looks like it should work. I suggest you
> open a "psql" session to the DB and type in all the commands that your
> program sends to the database. When you execute the "FETCH ALL"
> command, you should get an error message.
> You could also call the "char *PQerrorMessage(const PGconn* conn);"
> function after the "FETCH ALL" command fails.
> Hopefully the error message will guide you as to the problem.
> The binary cursor is only limited by your machine's memory.
> dave
> To unsubscribe from this group, send an email to:
> postgis-unsubscribe at yahoogroups.com
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Stop Smoking Now
Nicotrol will help
http://us.click.yahoo.com/2vN8tD/_pSDAA/ySSFAA/PhFolB/TM
