[postgis] JTS(Java Topology Suite) will be available until the end of this year.
Cameron Shorter cameron at shorter.net
Fri Dec 7 11:41:23 PST 2001
Is there any chance of an early release, even if it is just the base
types?
I'd really like to start using the base types (Point, Envelope, ...) as
building blocks for the work I'm doing.
I'm currently adding Web Map Server and Web Feature Server support to
http://geotools.sf.net as part of the http://mapbuilder.sf.net project.
mbdavis at vividsolutions.com wrote:
> Unfortunately the JTS delivery schedule has slipped a bit, due to some
> technical challenges with realizing our ambitious goal of developing robust
> code supporting an explicit precision model.
> We're hoping to have JTS 1.0 released by the end of December - check the Web
> site around that time for details.
> As for porting JTS to Java 1.1, JTS uses the Collections API pretty
> extensively, so it might be a bit of work converting it to Java 1.1.
> However, if that was done I don't think there are any fundamental
> limitations that would prevent it from working in 1.1.
> Martin Davis, Senior Technical Specialist
> Vivid Solutions Inc.
> Suite #1A-2328 Government Street   Victoria, B.C.   V8T 5G5
> Phone: (250) 385 6040    Fax: (250) 385 6046
> EMail: mbdavis at vividsolutions.com  Web: www.vividsolutions.com
> -----Original Message-----
> From: Hisaji ONO [mailto:ono96 at fa2.so-net.ne.jp]
> Sent: Friday, December 07, 2001 7:38 AM
> To: postgis at yahoogroups.com
> Subject: [postgis] JTS(Java Topology Suite) will be available until the
> end of this year.
> Hello.
>   JTS(Java Topology Suite), one of the greatest opensource GIS project, is
> still not available. This project's team will finish by the end of this
> year? And JTS is based on Java2, can it to ported to JDK 1.1.x ?  JTS seemed
> to use graphics, so converting to JDK 1.1.x will be easy.
> To unsubscribe from this group, send an email to:
> postgis-unsubscribe at yahoogroups.com
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Cameron Shorter          Web Mapping Manager
Social Change Online
248 Johnson St           Tel: +61 (0) 2 9692 5115
Annandale NSW 2038       Fax: +61 (0) 2 9692 5192
Sydney, Australia        http://webmap.socialchange.net.au
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Stop Smoking Now
Nicotrol will help
http://us.click.yahoo.com/2vN8tD/_pSDAA/ySSFAA/PhFolB/TM
