[postgis] JTS(Java Topology Suite) will be available until th e end of this year.
James Macgill
J.Macgill at geography.leeds.ac.uk
Tue Dec 11 04:42:10 PST 2001
>As for porting JTS to Java 1.1, JTS uses the Collections API pretty
>extensively, so it might be a bit of work converting it to Java 1.1.
>However, if that was done I don't think there are any fundamental
>limitations that would prevent it from working in 1.1.
That's not going to be a problem, GeoTools now automatically builds as two
versions, one for Java2 and one which uses suns Collections for Java1.1
extension.
I can probably apply the same automated translation to JTS once it's out so
that it can run under 1.1.
If you use ANT to manage your build process then I can send you a copy of
the relevant parts of out build scripts. The tricky bit is usually the use
of a small number of function which were added to random bits of Java2, and
these will have to be worked round by hand. I'm more than happy to do this
though.
I'm looking forward to the arrival of JTS, I'm hopeful that it can form a
common basis across a number of projects.
James
p.s. Appologies for carrying out what is essentially a JTS only discussion
on the postgis mailing list, but this seems to be the only appropriate
forum at the moment.
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Quit now for Great
American Smokeout
http://us.click.yahoo.com/0vN8tD/9pSDAA/ySSFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
