[postgis] Problem with MapServer/PostGis Compilation
Paul Ramsey
pramsey at refractions.net
Wed Dec 12 08:39:13 PST 2001
It looks like you have two conflicting versions of pgsql. Make sure the
version you compiled and installed is the only version on your system.
You might have postgresql RPMS installed from your default OS install.
shaphiro2000 wrote:
> Hi,
> I installed Postgresql 7.1.3, PostGis 0.6.2 and now I have compiled
> (CVS)MapServer with --with-postgis option but the system has showed
> me the
> following error (and warnigs):
> cmaplexer.c:3112: warning: `yyunput' defined but not used
> mapprimitive.c:771: warning: `get_centroid' defined but not used
> mapresample.c:419: warning: `msInitApproxTransformer' defined but not
> used
> mapresample.c:436: warning: `msFreeApproxTransformer' defined but not
> used
> mapresample.c:447: warning: `msApproxTransformer' defined but not used
> mapresample.c:551: warning: `msTransformMapToSource' defined but not
> used
> mapprojhack.c:71: warning: `ConvertProjUnitStringToMS' defined but
> not used
> /usr/lib/libpq.a(fe-connect.o): In function `connectDBStart':
> fe-connect.o(.text+0xa62): undefined reference to
> `SSL_load_error_strings'
> fe-connect.o(.text+0xa67): undefined reference to `SSL_library_init'
> fe-connect.o(.text+0xa6f): undefined reference to `SSLv23_method'
> fe-connect.o(.text+0xa77): undefined reference to `SSL_CTX_new'
> fe-connect.o(.text+0xa8c): undefined reference to `ERR_get_error'
> fe-connect.o(.text+0xa94): undefined reference to
> `ERR_reason_error_string'
> fe-connect.o(.text+0xab2): undefined reference to `SSL_new'
> fe-connect.o(.text+0xad5): undefined reference to `SSL_set_fd'
> fe-connect.o(.text+0xaee): undefined reference to `SSL_connect'
> fe-connect.o(.text+0xafd): undefined reference to `ERR_get_error'
> fe-connect.o(.text+0xb05): undefined reference to
> /usr/lib/libpq.a(fe-connect.o): In function `freePGconn':
> fe-connect.o(.text+0x1686): undefined reference to `SSL_free'
> /usr/lib/libpq.a(fe-misc.o): In function `pqReadData':
> fe-misc.o(.text+0x883): undefined reference to `SSL_read'
> fe-misc.o(.text+0x99e): undefined reference to `SSL_read'
> /usr/lib/libpq.a(fe-misc.o): In function `pqFlush':
> fe-misc.o(.text+0xb1f): undefined reference to `SSL_write'
> /usr/lib/libpq.a(fe-auth.o): In function `pg_krb5_init':
> fe-auth.o(.text+0x7c): undefined reference to `krb5_init_context'
> fe-auth.o(.text+0x8c): undefined reference to `error_message'
> fe-auth.o(.text+0xc2): undefined reference to `krb5_cc_default'
> fe-auth.o(.text+0xd2): undefined reference to `error_message'
> fe-auth.o(.text+0x13e): undefined reference to `error_message'
> fe-auth.o(.text+0x1a9): undefined reference to `krb5_unparse_name'
> fe-auth.o(.text+0x1b9): undefined reference to `error_message'
> fe-auth.o(.text+0x1e4): undefined reference to `krb5_free_principal'
> fe-auth.o(.text+0x211): undefined reference to `krb5_free_context'
> /usr/lib/libpq.a(fe-auth.o): In function `pg_krb5_sendauth':
> fe-auth.o(.text+0x2e7): undefined reference to
> `krb5_sname_to_principal'
> fe-auth.o(.text+0x2f7): undefined reference to `error_message'
> fe-auth.o(.text+0x38a): undefined reference to `krb5_free_principal'
> fe-auth.o(.text+0x3d2): undefined reference to `krb5_sendauth'
> fe-auth.o(.text+0x415): undefined reference to `error_message'
> fe-auth.o(.text+0x448): undefined reference to `krb5_free_error'
> fe-auth.o(.text+0x463): undefined reference to `krb5_free_principal'
> /usr/lib/libpq.a(fe-auth.o): In function `pg_password_sendauth':
> fe-auth.o(.text+0x4ec): undefined reference to `crypt'
> collect2: ld returned 1 exit status
> make: *** [shp2img] Error 1
> Why? In a very old newsgroup message (1998) I read about a
> NEED_CRYPT=-lcrypt option that unable the 'crypt errors', but, now,
> in the
> Makefile I doesn't find nothing about this.
> Thaks in advance.
> Stefano
> Outgoing mail is certified Virus Free.
> Checked by AVG anti-virus system (http://www.grisoft.com).
> Version: 6.0.306 / Virus Database: 166 - Release Date: 04/12/01
> To unsubscribe from this group, send an email to:
> postgis-unsubscribe at yahoogroups.com
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Stop Smoking Now
Nicotrol will help
http://us.click.yahoo.com/2vN8tD/_pSDAA/ySSFAA/PhFolB/TM
