[postgis] postgis build fails
James Reid James.Reid at ed.ac.uk
Mon Dec 17 06:03:08 PST 2001
hi ! Im trying to buils postgis 0.6.2 on posgresql-7.2b3 on a solaris 8 box with gcc and gmake - postgres is installed and working and Ive breated pl/pgsql but when I run a make on postgis it complains along the lines of the following:
postgis_ops.c: In function `ggeometry_compress':
postgis_ops.c:826: structure has no member named `pred'
postgis_ops.c:836: structure has no member named `pred'
postgis_ops.c:842: structure has no member named `pred'
postgis_ops.c:848: warning: assignment makes integer from pointer without a cast
postgis_ops.c:852: warning: assignment makes integer from pointer without a cast
postgis_ops.c: In function `ggeometry_consistent':
postgis_ops.c:876: structure has no member named `pred'
postgis_ops.c:881: structure has no member named `pred'
postgis_ops.c:887: structure has no member named `pred'
postgis_ops.c: In function `rtree_union':
postgis_ops.c:1060: structure has no member named `pred'
postgis_ops.c:1065: structure has no member named `pred'
postgis_ops.c: In function `rtree_penalty':
postgis_ops.c:1086: structure has no member named `pred'
postgis_ops.c:1090: structure has no member named `pred'
postgis_ops.c: In function `rtree_picksplit':
postgis_ops.c:1130: structure has no member named `pred'
postgis_ops.c:1132: structure has no member named `pred'
postgis_ops.c:1177: structure has no member named `pred'
postgis_ops.c:1179: structure has no member named `pred'
postgis_ops.c:1183: structure has no member named `pred'
postgis_ops.c:1185: structure has no member named `pred'
postgis_ops.c:1223: structure has no member named `pred'
postgis_ops.c:1248: warning: assignment makes integer from pointer without a cast
postgis_ops.c:1249: warning: assignment makes integer from pointer without a cast
make: *** [postgis_ops.o] Error 1
any thoughts?
James at Blackgrid.co.uk
"Every program has two purposes -- one for which it was written and another for which it wasn't. "
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Unlimited calling with 3-way conferencing. Only $1/Mo.
with CrystalVoice! FREE trial. Click Here.
http://us.click.yahoo.com/Hb1xVB/HxbDAA/ySSFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
