[postgis] compiling postgis in cygwin
Norman Vine
nhv at cape.com
Fri Jun 15 21:42:32 PDT 2001
Doug Nebert writes:
>I was also unable to compile Postgres in Win2K with features in cygwin
>but noticed that a pared down version pgsql came with cygwin
>but had no source or contrib with it. So I followed the directions and
>installed the Postgres source as described and the IPC stuff too. When
>I attempt the ./configure I get the error:
>"The procedure entry point getrlimit could not be located in
>the dynamic
>link library cygwin1.dll"
>even before I tried adding the postgis features.
>This is a very fresh version of cygwin which I installed twice.
>What's up?
Doug
The way I did this was
1) Use the Cygwin setup tool to get the Cygwin PostGres source
this will install itself into /usr/src/postgres-xxx
2) un tar postgis into contrib
3) used these configure args to setup the postgres master makefile correctly
./configure --enable-multibyte --with-CXX --prefix=/usr --sysconfdir=/etc --
docdir=/usr/doc/postgresql-$version
make
Do not do make install as the supplied Cygwin binary has java support
builtin
which requires a LOT of work
4) cd to contrib/postgis and make and install postgis ala instrucrions in
readme
FWIW
I have temporarily placed at
http://www.vso.cape.com/~nhv/files/cygwin/cygwin_postgis.tgz
This was built against a Cygwin Installation built from todays Cygwin CVS
files
but I think that the above method should work just fine with the 1.3.2
distribution
Holler again if this doesn't work for you.
Cheers
Norman Vine
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
