[postgis] OGR and PostGIS
Paul Ramsey
pramsey at refractions.net
Tue Jun 19 12:20:07 PDT 2001
Frank Warmerdam wrote:
> I have run the provided tests, and got a few variations. Are these of
> any concern? Note that the "make test" script doesn't seem to preclean
> the output files, so I wasted a few minutes with that.
Frankly, our regression test could use alot of work, it's hardly better
than nothing at all at this point.
> This insert:
> INSERT INTO geom_test ( gid, geom, name )
> VALUES ( 1, 'POLYGON((0 0 0,0 5 0,5 5 0,5 0 0,0 0 0))', '3D Square');
> Resulted in this from a select *:
> 1 | POLYGON((0 0 0,0 5.31146529464635e-315 0,5.31146529464635e-315 5.31146529464635e-315 0,5.31146529464635e-315 0 0,0 0 0)) | 3D Square
This is very disturbing... suffice to say, the same thing doesn't happen
on our installation... I will try and get PostgreSQL/PostGIS running on
a Linux box here and see if we can duplicate it. Does the problem
*always* happen, or did it happen just the first time you tried that
particular geometry?
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
