[postgis] OGR and PostGIS
Tue Jun 19 12:30:42 PDT 2001
Paul Ramsey wrote:
> Frank Warmerdam wrote:
> > I have run the provided tests, and got a few variations.  Are these of
> > any concern?   Note that the "make test" script doesn't seem to preclean
> > the output files, so I wasted a few minutes with that.
> Frankly, our regression test could use alot of work, it's hardly better
> than nothing at all at this point.
> > This insert:
> > INSERT INTO geom_test ( gid, geom, name )
> >   VALUES ( 1, 'POLYGON((0 0 0,0 5 0,5 5 0,5 0 0,0 0 0))', '3D Square');
> > Resulted in this from a select *:
> >    1 | POLYGON((0 0 0,0 5.31146529464635e-315 0,5.31146529464635e-315 5.31146529464635e-315 0,5.31146529464635e-315 0 0,0 0 0)) | 3D Square
> This is very disturbing... suffice to say, the same thing doesn't happen
> on our installation... I will try and get PostgreSQL/PostGIS running on
> a Linux box here and see if we can duplicate it. Does the problem
> *always* happen, or did it happen just the first time you tried that
> particular geometry?
Paul,
It happened twice on the same insert statement, while the rest were fine
so it is reproducable.  I will try doing a little debugging on this myself
and see if I can figure out what is going on.  A good chance to get my hands
wet on the code.  I can also provide a login account on my system for debugging
if I can't figure it out myself.
Best regards,
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
