[postgis] PostGIS relationship to SFSQL Specification
Frank Warmerdam
warmerdam at pobox.com
Tue Jun 19 12:23:20 PDT 2001
Guys,
I am reviewing the OGC SFSQL specification and I am wondering about how
closely you are interested in following it. In my dreams, PostGIS would
implmeent a useful subset of the SFSQL "Types and Functions" specification
in a manner that would make it relatively easy to port applications between
this environment and other environments claiming to implement SFSQL (SDE?
Oracle?).
If this is a reasonable goal, could we start following the spec now as
new features are introduced? For instance, the progress report on Saturday
mentioned that the new wkb_ndr() and wkb_xdr() functions are being added.
A cursory review of the SFSQL spec suggests the equivelent function from it
is called AsBinary() and that there is no control of the byte order. I
would suggest using this, and adding an optional argument to control XDR/NDR
byte order defaulting to what ever is most convenient when that argument isn't
given.
I haven't reviewed the other features of PostGIS for their relatinship with
SFSQL, but it seems that there are other possibly unnecessary differences as
well. For instance, are the geometry tests done in a syntactically
equivelent way for the amount that PostGIS wishes to implement?
Looking through postgis.txt I do see a few more examples. For instance, the
SFSQL geometry types can be operated on by a Length() operator, which is
presumably the same as the PostGIS length2d() operator. The PostGIS npoints()
operator is similar to the NumPoints() operator in SFSQL.
So, can we strive towards SFSQL compliance, even if we don't intend to
implement everything?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
