[postgis] PostGIS relationship to SFSQL Specification
Paul Ramsey
pramsey at refractions.net
Tue Jun 19 12:29:00 PDT 2001
This is a really good idea. I'll haul out our SFSQL binder for Dave...
Frank Warmerdam wrote:
> Guys,
> I am reviewing the OGC SFSQL specification and I am wondering about how
> closely you are interested in following it. In my dreams, PostGIS would
> implmeent a useful subset of the SFSQL "Types and Functions" specification
> in a manner that would make it relatively easy to port applications between
> this environment and other environments claiming to implement SFSQL (SDE?
> Oracle?).
> If this is a reasonable goal, could we start following the spec now as
> new features are introduced? For instance, the progress report on Saturday
> mentioned that the new wkb_ndr() and wkb_xdr() functions are being added.
> A cursory review of the SFSQL spec suggests the equivelent function from it
> is called AsBinary() and that there is no control of the byte order. I
> would suggest using this, and adding an optional argument to control XDR/NDR
> byte order defaulting to what ever is most convenient when that argument isn't
> given.
> I haven't reviewed the other features of PostGIS for their relatinship with
> SFSQL, but it seems that there are other possibly unnecessary differences as
> well. For instance, are the geometry tests done in a syntactically
> equivelent way for the amount that PostGIS wishes to implement?
> Looking through postgis.txt I do see a few more examples. For instance, the
> SFSQL geometry types can be operated on by a Length() operator, which is
> presumably the same as the PostGIS length2d() operator. The PostGIS npoints()
> operator is similar to the NumPoints() operator in SFSQL.
> So, can we strive towards SFSQL compliance, even if we don't intend to
> implement everything?
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> To unsubscribe from this group, send an email to:
> postgis-unsubscribe at yahoogroups.com
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
