[postgis] Re: OGI SF SQL ?
valentine
valentine at sdc.ucsb.edu
Thu Nov 8 23:25:50 PST 2001
>(Incidentally, a geometrycollection of a single polygon
> is a bit redundant, is it possible your WKT dumper is
overgeneralizing,
> or do you truly have heterogeneous geometry collections to insert
into
> the database?)
It does contain true heterogeneous information, st_geometry contains,
points, polygons, lines, point&polygon, and a plan for polygon&line
I will give it a try, then.
dave valentine
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
