[postgis] Re:shp2pgsql
Hisaji ONO
ono96 at fa2.so-net.ne.jp
Thu Sep 27 05:27:12 PDT 2001
I have created following quick and dirty two php scripts(svgmap.php,
wkt2svg.php) for creating SVG instances from WKT(Point & Polygon) which
are returned by PostGIS as a result of spatial queries.
You must install SVG Adobe Viewer Plug-In (http://www.adobe.com/svg)
Ver 2.0 or later into your PC if it not installed..
And change your DB info(host, ID etc.) and table info for your data.
Sorry, these scripts are incomplete for dealing with inner polygons and
multi-polygons.
List1 svgmap.php
<?php
include("wkt2svg.inc"); # load wkt2svg
// Main
showHeader();
// Set DB Connection Info
$hostName = "your host name";
$USR = "your-id";
$PASSWRD = "your password";
$TABLE="your database name";
$dbcon = pg_connect("host=".$hostName." user=".$USR ."
password=".$PASSWRD." dbname=".$TABLE); # connect to DB
if (!$dbcon) { die("<hr>pg_connect </hr>");}
$sql= "SET ENABLE_SEQSCAN = OFF";
$execid = pg_exec ($dbcon, $sql);
$layerName = "your table name"; # Polygon Geometry included
$sql= "SELECT extent(GEO_VALUE) FROM ".$layerName; # get Map Extent
if (!$execid){
} else {
$resultstr = pg_result($execid,0,0);
$extent = getExtent($resultstr);
// create extent
createExtent($extent);
// Polygon Layer
$layerName="your table name";# Polygon Geometry included
$fillColor = "cyan"; # filled Color name or hex
$outlineColot = "blue"; # out line # Polygon Geometry included
$where = "geoid >= 0"; # condition
getPolygons($dbcon, $layerName, $fillColor, $outlineColot,$where);
// LineString Layer
$layerName="eki";# Point Geometry included
getPoints($dbcon, $layerName);
// close SVG
createFooter();
List 2 wkt2svg
//XML header
function showHeader(){
header("Content-type: image/svg-xml");
//Header
print('<?xml version="1.0" encoding="iso-8859-1"?>' . "\n");
print('<!DOCTYPE svg PUBLIC "-//W3C//DTD SVG //EN" ');
print('"http://www.w3.org/TR/2001/ PR-SVG-20010719/DTD/' .
'svg10.dtd">' . "\n");
//generate a tag for extent
function createExtent($extent){
$xmin = $extent[0];
$ymin = $extent[1];
$width= $extent[3] - $extent[0];
$height= $extent[4] - $extent[1];
$height2= $extent[4] + $extent[1];
//print '<svg width="512" height="512" viewBox="'.$xmin.' '.$ymin.'
'.$width.' '.$height.'">';
print '<svg viewBox="'.$xmin.' '.$ymin.' '.$width.' '.$height.'">';
print '<g transform="matrix(1 0 0 -1 0 '.$height2.')" >'; #Affine
//close svg
function createFooter(){
print '</g>';
print('</svg>' . "\n");
//get extent
function getExtent($result){
$tmpstr = str_replace("BOX3D(", "", $result);
$tmpstr = str_replace(")", "", $tmpstr);
$tmpstr = str_replace(",", " ", $tmpstr);
return explode(" ", $tmpstr);
//start a layer or g group
function layerHeader(){
print('<g>' . "\n");
//close a layer
function layerFooter(){
print('</g>' . "\n");
//get coordinates of points
function getPoints($dbcon, $layerName){
$sql= "SELECT geoid, x(GEO_VALUE), y(GEO_VALUE) FROM ".$layerName;
print('<g id="'.$layerName.'">' . "\n");
for ($i=0;$i < pg_numrows($execid);$i++){
$id = pg_result($execid,$i,0); //id
$x= pg_result($execid,$i,1); // X
$y = pg_result($execid,$i,2); // Y
print '<circle style="fill:red;fill-stroke:blue;" id="'.$id.'"
cx="'.$x.'" cy="'.$y.'" r="100px"/>';
print('</g>');
// create a Path for a Polygon
function getPolygons($dbcon, $layerName, $fillColor,$outlineColor,
$where){
if($where == "")
$sql= "SELECT exteriorring(GEO_VALUE) FROM ".$layerName;
else
$sql= "SELECT exteriorring(GEO_VALUE) FROM ".$layerName." WHERE
".$where;
$exterior = pg_result($execid,$i,0);
//remove SRID=-1;
$tempstr = explode(";", $exterior);
$exterior = $tempstr[1];
print '<path
style="fill:'.$fillColor.';stroke:'.$outlineColor.';stroke-width:22"
d="'.createPolygonPath($exterior).'" />';
print('</g>');
// generate a path
function createPolygonPath($result){
$tmpstr = str_replace("LINESTRING(", "", $result);
$tmpstr = str_replace(",", "L", $tmpstr);
$tmpstr = str_replace(" ", ",", $tmpstr);
return "M".$tmpstr."z";
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20010927/f8fb7bcd/attachment.html>
