[postgis-users] proj parameters from srtext?
Sean Gillies sgillies at i3.com
Fri Apr 19 10:13:33 PDT 2002
Bernhard,
The Proj.4 distribution contains a file named "epsg" that has
a mapping between EPSG codes (SRID) and the Proj.4 parameter strings.
It's straightforward to create SQL commands from this file
and update the spatial_ref_sys table with the appropriate values.
I guess that they are not including Proj.4 parameters in
spatial_ref_sys.sql because they don't want to tie you to a
particular version of Proj.4.
Sean
Bernhard Reiter wrote:
> Is there a standard procedure find out the proj4text values
> from the srtext descriptions in the accompained spatial_ref_sys.sql?
> Or will future revision of postgis' spatial_ref_sys.sql
> contain the projections that proj can handle?
> I assume there is no good tables for this
> otherwise somebody would already have filled it. :)
> 	Bernhard
