[postgis-users] Re: C question, PG_RETURN_POINTER: GPC integration
Nicolas Ribot
nicolas.ribot at scot.cnes.fr
Tue Apr 30 07:35:26 PDT 2002
Mr Ono,
(and maybe other people interested)
Here are the files (scot_gpc.c and scot_gpc.h).
I tested the functions with very simple geometries.
I join to the c files a sql file containing the dump of the postgis table
(testgpc).
> Thank you very much, Mr. Ribot. I'd like to try some geometries using your
> functions.
> Regards.
> postgis-users mailing list
Project: Generic Polygon Clipper
A new algorithm for calculating the difference, intersection,
exclusive-or or union of arbitrary polygon sets.
File: gpc.h
Author: Alan Murta (email: gpc at cs.man.ac.uk)
Version: 2.31
Date: 4th June 1999
Copyright: (C) 1997-1999, Advanced Interfaces Group,
University of Manchester.
This software is free for non-commercial use. It may be copied,
modified, and redistributed provided that this copyright notice
is preserved on all copies. The intellectual property rights of
the algorithms used reside with the University of Manchester
Advanced Interfaces Group.
You may not use this software, in whole or in part, in support
of any commercial product without the express consent of the
author.
There is no warranty or other guarantee of fitness of this
software for any purpose. It is provided solely "as is".
#ifndef __gpc_h
#define __gpc_h
#include <stdio.h>
Constants
/* Increase GPC_EPSILON to encourage merging of near coincident edges */
#define GPC_EPSILON (DBL_EPSILON)
#define GPC_VERSION "2.31"
Public Data Types
typedef enum /* Set operation type */
GPC_DIFF, /* Difference */
GPC_INT, /* Intersection */
GPC_XOR, /* Exclusive or */
GPC_UNION /* Union */
} gpc_op;
typedef struct /* Polygon vertex structure */
double x; /* Vertex x component */
double y; /* vertex y component */
} gpc_vertex;
typedef struct /* Vertex list structure */
int num_vertices; /* Number of vertices in list */
gpc_vertex *vertex; /* Vertex array pointer */
} gpc_vertex_list;
typedef struct /* Polygon set structure */
int num_contours; /* Number of contours in polygon */
int *hole; /* Hole / external contour flags */
gpc_vertex_list *contour; /* Contour array pointer */
} gpc_polygon;
typedef struct /* Tristrip set structure */
int num_strips; /* Number of tristrips */
gpc_vertex_list *strip; /* Tristrip array pointer */
} gpc_tristrip;
Public Function Prototypes
void gpc_read_polygon (FILE *infile_ptr,
int read_hole_flags,
gpc_polygon *polygon);
void gpc_write_polygon (FILE *outfile_ptr,
int write_hole_flags,
void gpc_add_contour (gpc_polygon *polygon,
gpc_vertex_list *contour,
int hole);
void gpc_polygon_clip (gpc_op set_operation,
gpc_polygon *subject_polygon,
gpc_polygon *clip_polygon,
gpc_polygon *result_polygon);
void gpc_tristrip_clip (gpc_op set_operation,
gpc_tristrip *result_tristrip);
void gpc_polygon_to_tristrip (gpc_polygon *polygon,
gpc_tristrip *tristrip);
void gpc_free_polygon (gpc_polygon *polygon);
void gpc_free_tristrip (gpc_tristrip *tristrip);
#endif
End of file: gpc.h
File: gpc.c
Version: 2.31
Date: 4th June 1999
author.
Includes
#include "gpc.h"
#include <stdlib.h>
#include <float.h>
#include <math.h>
Constants
#ifndef TRUE
#define FALSE 0
#define TRUE 1
#endif
#define LEFT 0
#define RIGHT 1
#define ABOVE 0
#define BELOW 1
#define CLIP 0
#define SUBJ 1
#define INVERT_TRISTRIPS FALSE
Macros
#define EQ(a, b) (fabs((a) - (b)) <= GPC_EPSILON)
#define PREV_INDEX(i, n) ((i - 1 + n) % n)
#define NEXT_INDEX(i, n) ((i + 1 ) % n)
#define OPTIMAL(v, i, n) ((v[PREV_INDEX(i, n)].y != v[i].y) || \
(v[NEXT_INDEX(i, n)].y != v[i].y))
#define FWD_MIN(v, i, n) ((v[PREV_INDEX(i, n)].vertex.y >= v[i].vertex.y) \
&& (v[NEXT_INDEX(i, n)].vertex.y > v[i].vertex.y))
#define NOT_FMAX(v, i, n) (v[NEXT_INDEX(i, n)].vertex.y > v[i].vertex.y)
#define REV_MIN(v, i, n) ((v[PREV_INDEX(i, n)].vertex.y > v[i].vertex.y) \
&& (v[NEXT_INDEX(i, n)].vertex.y >= v[i].vertex.y))
#define NOT_RMAX(v, i, n) (v[PREV_INDEX(i, n)].vertex.y > v[i].vertex.y)
#define VERTEX(e,p,s,x,y) {add_vertex(&((e)->outp[(p)]->v[(s)]), x, y); \
(e)->outp[(p)]->active++;}
#define P_EDGE(d,e,p,i,j) {(d)= (e); \
do {(d)= (d)->prev;} while (!(d)->outp[(p)]); \
(i)= (d)->bot.x + (d)->dx * ((j)-(d)->bot.y);}
#define N_EDGE(d,e,p,i,j) {(d)= (e); \
do {(d)= (d)->next;} while (!(d)->outp[(p)]); \
#define MALLOC(p, b, s) {if ((b) > 0) { \
p= malloc(b); if (!(p)) { \
fprintf(stderr, "gpc malloc failure: %s\n", s); \
exit(0);}} else p= NULL;}
#define FREE(p) {if (p) {free(p); (p)= NULL;}}
Private Data Types
typedef enum /* Edge intersection classes */
NUL, /* Empty non-intersection */
EMX, /* External maximum */
ELI, /* External left intermediate */
TED, /* Top edge */
ERI, /* External right intermediate */
RED, /* Right edge */
IMM, /* Internal maximum and minimum */
IMN, /* Internal minimum */
EMN, /* External minimum */
EMM, /* External maximum and minimum */
LED, /* Left edge */
ILI, /* Internal left intermediate */
BED, /* Bottom edge */
IRI, /* Internal right intermediate */
IMX, /* Internal maximum */
FUL /* Full non-intersection */
} vertex_type;
typedef enum /* Horizontal edge states */
NH, /* No horizontal edge */
BH, /* Bottom horizontal edge */
TH /* Top horizontal edge */
} h_state;
typedef enum /* Edge bundle state */
UNBUNDLED, /* Isolated edge not within a bundle */
BUNDLE_HEAD, /* Bundle head node */
BUNDLE_TAIL /* Passive bundle tail node */
} bundle_state;
typedef struct v_shape /* Internal vertex list datatype */
double x; /* X coordinate component */
double y; /* Y coordinate component */
struct v_shape *next; /* Pointer to next vertex in list */
} vertex_node;
typedef struct p_shape /* Internal contour / tristrip type */
int active; /* Active flag / vertex count */
int hole; /* Hole / external contour flag */
vertex_node *v[2]; /* Left and right vertex list ptrs */
struct p_shape *next; /* Pointer to next polygon contour */
struct p_shape *proxy; /* Pointer to actual structure used */
} polygon_node;
typedef struct edge_shape
gpc_vertex vertex; /* Piggy-backed contour vertex data */
gpc_vertex bot; /* Edge lower (x, y) coordinate */
gpc_vertex top; /* Edge upper (x, y) coordinate */
double xb; /* Scanbeam bottom x coordinate */
double xt; /* Scanbeam top x coordinate */
double dx; /* Change in x for a unit y increase */
int type; /* Clip / subject edge flag */
int bundle[2][2]; /* Bundle edge flags */
int bside[2]; /* Bundle left / right indicators */
bundle_state bstate[2]; /* Edge bundle state */
polygon_node *outp[2]; /* Output polygon / tristrip pointer */
struct edge_shape *prev; /* Previous edge in the AET */
struct edge_shape *next; /* Next edge in the AET */
struct edge_shape *pred; /* Edge connected at the lower end */
struct edge_shape *succ; /* Edge connected at the upper end */
struct edge_shape *next_bound; /* Pointer to next bound in LMT */
} edge_node;
typedef struct lmt_shape /* Local minima table */
double y; /* Y coordinate at local minimum */
edge_node *first_bound; /* Pointer to bound list */
struct lmt_shape *next; /* Pointer to next local minimum */
} lmt_node;
typedef struct sbt_t_shape /* Scanbeam tree */
double y; /* Scanbeam node y value */
struct sbt_t_shape *less; /* Pointer to nodes with lower y */
struct sbt_t_shape *more; /* Pointer to nodes with higher y */
} sb_tree;
typedef struct it_shape /* Intersection table */
edge_node *ie[2]; /* Intersecting edge (bundle) pair */
gpc_vertex point; /* Point of intersection */
struct it_shape *next; /* The next intersection table node */
} it_node;
typedef struct st_shape /* Sorted edge table */
edge_node *edge; /* Pointer to AET edge */
struct st_shape *prev; /* Previous edge in sorted list */
} st_node;
typedef struct bbox_shape /* Contour axis-aligned bounding box */
double xmin; /* Minimum x coordinate */
double ymin; /* Minimum y coordinate */
double xmax; /* Maximum x coordinate */
double ymax; /* Maximum y coordinate */
} bbox;
Global Data
/* Horizontal edge state transitions within scanbeam boundary */
const h_state next_h_state[3][6]=
/* ABOVE BELOW CROSS */
/* L R L R L R */
/* NH */ {BH, TH, TH, BH, NH, NH},
/* BH */ {NH, NH, NH, NH, TH, TH},
/* TH */ {NH, NH, NH, NH, BH, BH}
Private Functions
static void reset_it(it_node **it)
it_node *itn;
while (*it)
itn= (*it)->next;
FREE(*it);
*it= itn;
static void reset_lmt(lmt_node **lmt)
lmt_node *lmtn;
while (*lmt)
lmtn= (*lmt)->next;
FREE(*lmt);
*lmt= lmtn;
static void insert_bound(edge_node **b, edge_node *e)
edge_node *existing_bound;
if (!*b)
/* Link node e to the tail of the list */
*b= e;
else
/* Do primary sort on the x field */
if (e[0].bot.x < (*b)[0].bot.x)
/* Insert a new node mid-list */
existing_bound= *b;
*b= e;
(*b)->next_bound= existing_bound;
else
if (e[0].bot.x == (*b)[0].bot.x)
/* Do secondary sort on the dx field */
if (e[0].dx < (*b)[0].dx)
existing_bound= *b;
*b= e;
else
/* Head further down the list */
insert_bound(&((*b)->next_bound), e);
else
static edge_node **bound_list(lmt_node **lmt, double y)
lmt_node *existing_node;
if (!*lmt)
/* Add node onto the tail end of the LMT */
MALLOC(*lmt, sizeof(lmt_node), "LMT insertion");
(*lmt)->y= y;
(*lmt)->first_bound= NULL;
(*lmt)->next= NULL;
return &((*lmt)->first_bound);
else
if (y < (*lmt)->y)
/* Insert a new LMT node before the current node */
existing_node= *lmt;
(*lmt)->y= y;
(*lmt)->next= existing_node;
else
if (y > (*lmt)->y)
/* Head further up the LMT */
return bound_list(&((*lmt)->next), y);
else
/* Use this existing LMT node */
static void add_to_sbtree(int *entries, sb_tree **sbtree, double y)
if (!*sbtree)
/* Add a new tree node here */
MALLOC(*sbtree, sizeof(sb_tree), "scanbeam tree insertion");
(*sbtree)->y= y;
(*sbtree)->less= NULL;
(*sbtree)->more= NULL;
(*entries)++;
else
if ((*sbtree)->y > y)
/* Head into the 'less' sub-tree */
add_to_sbtree(entries, &((*sbtree)->less), y);
else
if ((*sbtree)->y < y)
/* Head into the 'more' sub-tree */
add_to_sbtree(entries, &((*sbtree)->more), y);
static void build_sbt(int *entries, double *sbt, sb_tree *sbtree)
if (sbtree->less)
build_sbt(entries, sbt, sbtree->less);
sbt[*entries]= sbtree->y;
(*entries)++;
if (sbtree->more)
build_sbt(entries, sbt, sbtree->more);
static void free_sbtree(sb_tree **sbtree)
if (*sbtree)
free_sbtree(&((*sbtree)->less));
free_sbtree(&((*sbtree)->more));
FREE(*sbtree);
static int count_optimal_vertices(gpc_vertex_list c)
int result= 0, i;
/* Ignore non-contributing contours */
if (c.num_vertices > 0)
for (i= 0; i < c.num_vertices; i++)
/* Ignore superfluous vertices embedded in horizontal edges */
if (OPTIMAL(c.vertex, i, c.num_vertices))
result++;
return result;
static edge_node *build_lmt(lmt_node **lmt, sb_tree **sbtree,
int *sbt_entries, gpc_polygon *p, int type,
gpc_op op)
int c, i, min, max, num_edges, v, num_vertices;
int total_vertices= 0, e_index=0;
edge_node *e, *edge_table;
for (c= 0; c < p->num_contours; c++)
total_vertices+= count_optimal_vertices(p->contour[c]);
/* Create the entire input polygon edge table in one go */
MALLOC(edge_table, total_vertices * sizeof(edge_node),
"edge table creation");
if (p->contour[c].num_vertices < 0)
/* Ignore the non-contributing contour and repair the vertex count */
p->contour[c].num_vertices= -p->contour[c].num_vertices;
else
/* Perform contour optimisation */
num_vertices= 0;
for (i= 0; i < p->contour[c].num_vertices; i++)
if (OPTIMAL(p->contour[c].vertex, i, p->contour[c].num_vertices))
edge_table[num_vertices].vertex.x= p->contour[c].vertex[i].x;
edge_table[num_vertices].vertex.y= p->contour[c].vertex[i].y;
/* Record vertex in the scanbeam table */
add_to_sbtree(sbt_entries, sbtree,
edge_table[num_vertices].vertex.y);
num_vertices++;
/* Do the contour forward pass */
for (min= 0; min < num_vertices; min++)
/* If a forward local minimum... */
if (FWD_MIN(edge_table, min, num_vertices))
/* Search for the next local maximum... */
num_edges= 1;
max= NEXT_INDEX(min, num_vertices);
while (NOT_FMAX(edge_table, max, num_vertices))
num_edges++;
max= NEXT_INDEX(max, num_vertices);
/* Build the next edge list */
e= &edge_table[e_index];
e_index+= num_edges;
v= min;
e[0].bstate[BELOW]= UNBUNDLED;
e[0].bundle[BELOW][CLIP]= FALSE;
e[0].bundle[BELOW][SUBJ]= FALSE;
for (i= 0; i < num_edges; i++)
e[i].xb= edge_table[v].vertex.x;
e[i].bot.x= edge_table[v].vertex.x;
e[i].bot.y= edge_table[v].vertex.y;
v= NEXT_INDEX(v, num_vertices);
e[i].top.x= edge_table[v].vertex.x;
e[i].top.y= edge_table[v].vertex.y;
e[i].dx= (edge_table[v].vertex.x - e[i].bot.x) /
(e[i].top.y - e[i].bot.y);
e[i].type= type;
e[i].outp[ABOVE]= NULL;
e[i].outp[BELOW]= NULL;
e[i].next= NULL;
e[i].prev= NULL;
e[i].succ= ((num_edges > 1) && (i < (num_edges - 1))) ?
&(e[i + 1]) : NULL;
e[i].pred= ((num_edges > 1) && (i > 0)) ? &(e[i - 1]) : NULL;
e[i].next_bound= NULL;
e[i].bside[CLIP]= (op == GPC_DIFF) ? RIGHT : LEFT;
e[i].bside[SUBJ]= LEFT;
insert_bound(bound_list(lmt, edge_table[min].vertex.y), e);
/* Do the contour reverse pass */
/* If a reverse local minimum... */
if (REV_MIN(edge_table, min, num_vertices))
/* Search for the previous local maximum... */
num_edges= 1;
max= PREV_INDEX(min, num_vertices);
while (NOT_RMAX(edge_table, max, num_vertices))
num_edges++;
max= PREV_INDEX(max, num_vertices);
/* Build the previous edge list */
v= min;
v= PREV_INDEX(v, num_vertices);
e[i].type= type;
e[i].next= NULL;
e[i].prev= NULL;
&(e[i + 1]) : NULL;
return edge_table;
static void add_edge_to_aet(edge_node **aet, edge_node *edge, edge_node *prev)
if (!*aet)
/* Append edge onto the tail end of the AET */
*aet= edge;
edge->prev= prev;
edge->next= NULL;
else
/* Do primary sort on the xb field */
if (edge->xb < (*aet)->xb)
/* Insert edge here (before the AET edge) */
edge->prev= prev;
edge->next= *aet;
(*aet)->prev= edge;
*aet= edge;
else
if (edge->xb == (*aet)->xb)
if (edge->dx < (*aet)->dx)
edge->prev= prev;
edge->next= *aet;
(*aet)->prev= edge;
*aet= edge;
else
/* Head further into the AET */
add_edge_to_aet(&((*aet)->next), edge, *aet);
else
static void add_intersection(it_node **it, edge_node *edge0, edge_node *edge1,
double x, double y)
it_node *existing_node;
if (!*it)
/* Append a new node to the tail of the list */
MALLOC(*it, sizeof(it_node), "IT insertion");
(*it)->ie[0]= edge0;
(*it)->ie[1]= edge1;
(*it)->point.x= x;
(*it)->point.y= y;
(*it)->next= NULL;
else
if ((*it)->point.y > y)
existing_node= *it;
(*it)->point.x= x;
(*it)->point.y= y;
(*it)->next= existing_node;
else
add_intersection(&((*it)->next), edge0, edge1, x, y);
static void add_st_edge(st_node **st, it_node **it, edge_node *edge,
double dy)
st_node *existing_node;
double den, r, x, y;
if (!*st)
/* Append edge onto the tail end of the ST */
MALLOC(*st, sizeof(st_node), "ST insertion");
(*st)->edge= edge;
(*st)->xb= edge->xb;
(*st)->xt= edge->xt;
(*st)->dx= edge->dx;
(*st)->prev= NULL;
else
den= ((*st)->xt - (*st)->xb) - (edge->xt - edge->xb);
/* If new edge and ST edge don't cross */
if ((edge->xt >= (*st)->xt) || (edge->dx == (*st)->dx) ||
(fabs(den) <= DBL_EPSILON))
/* No intersection - insert edge here (before the ST edge) */
existing_node= *st;
(*st)->edge= edge;
(*st)->prev= existing_node;
else
/* Compute intersection between new edge and ST edge */
r= (edge->xb - (*st)->xb) / den;
x= (*st)->xb + r * ((*st)->xt - (*st)->xb);
y= r * dy;
/* Insert the edge pointers and the intersection point in the IT */
add_intersection(it, (*st)->edge, edge, x, y);
/* Head further into the ST */
add_st_edge(&((*st)->prev), it, edge, dy);
static void build_intersection_table(it_node **it, edge_node *aet, double dy)
st_node *st, *stp;
edge_node *edge;
/* Build intersection table for the current scanbeam */
reset_it(it);
st= NULL;
/* Process each AET edge */
for (edge= aet; edge; edge= edge->next)
if ((edge->bstate[ABOVE] == BUNDLE_HEAD) ||
edge->bundle[ABOVE][CLIP] || edge->bundle[ABOVE][SUBJ])
add_st_edge(&st, it, edge, dy);
/* Free the sorted edge table */
while (st)
stp= st->prev;
FREE(st);
st= stp;
static int count_contours(polygon_node *polygon)
int nc, nv;
vertex_node *v, *nextv;
for (nc= 0; polygon; polygon= polygon->next)
if (polygon->active)
/* Count the vertices in the current contour */
nv= 0;
for (v= polygon->proxy->v[LEFT]; v; v= v->next)
nv++;
/* Record valid vertex counts in the active field */
if (nv > 2)
polygon->active= nv;
nc++;
else
/* Invalid contour: just free the heap */
for (v= polygon->proxy->v[LEFT]; v; v= nextv)
nextv= v->next;
FREE(v);
polygon->active= 0;
return nc;
static void add_left(polygon_node *p, double x, double y)
vertex_node *nv;
/* Create a new vertex node and set its fields */
MALLOC(nv, sizeof(vertex_node), "vertex node creation");
nv->x= x;
nv->y= y;
/* Add vertex nv to the left end of the polygon's vertex list */
nv->next= p->proxy->v[LEFT];
/* Update proxy->[LEFT] to point to nv */
p->proxy->v[LEFT]= nv;
static void merge_left(polygon_node *p, polygon_node *q, polygon_node *list)
polygon_node *target;
/* Label contour as a hole */
q->proxy->hole= TRUE;
if (p->proxy != q->proxy)
/* Assign p's vertex list to the left end of q's list */
p->proxy->v[RIGHT]->next= q->proxy->v[LEFT];
q->proxy->v[LEFT]= p->proxy->v[LEFT];
/* Redirect any p->proxy references to q->proxy */
for (target= p->proxy; list; list= list->next)
if (list->proxy == target)
list->active= FALSE;
list->proxy= q->proxy;
static void add_right(polygon_node *p, double x, double y)
vertex_node *nv;
nv->x= x;
nv->y= y;
nv->next= NULL;
/* Add vertex nv to the right end of the polygon's vertex list */
p->proxy->v[RIGHT]->next= nv;
/* Update proxy->v[RIGHT] to point to nv */
p->proxy->v[RIGHT]= nv;
static void merge_right(polygon_node *p, polygon_node *q, polygon_node *list)
/* Label contour as external */
q->proxy->hole= FALSE;
/* Assign p's vertex list to the right end of q's list */
q->proxy->v[RIGHT]->next= p->proxy->v[LEFT];
q->proxy->v[RIGHT]= p->proxy->v[RIGHT];
static void add_local_min(polygon_node **p, edge_node *edge,
double x, double y)
polygon_node *existing_min;
vertex_node *nv;
existing_min= *p;
MALLOC(*p, sizeof(polygon_node), "polygon node creation");
nv->x= x;
nv->y= y;
nv->next= NULL;
/* Initialise proxy to point to p itself */
(*p)->proxy= (*p);
(*p)->active= TRUE;
(*p)->next= existing_min;
/* Make v[LEFT] and v[RIGHT] point to new vertex nv */
(*p)->v[LEFT]= nv;
(*p)->v[RIGHT]= nv;
/* Assign polygon p to the edge */
edge->outp[ABOVE]= *p;
static int count_tristrips(polygon_node *tn)
int total;
for (total= 0; tn; tn= tn->next)
if (tn->active > 2)
total++;
return total;
static void add_vertex(vertex_node **t, double x, double y)
if (!(*t))
MALLOC(*t, sizeof(vertex_node), "tristrip vertex creation");
(*t)->x= x;
(*t)->y= y;
(*t)->next= NULL;
else
add_vertex(&((*t)->next), x, y);
static void new_tristrip(polygon_node **tn, edge_node *edge,
double x, double y)
if (!(*tn))
MALLOC(*tn, sizeof(polygon_node), "tristrip node creation");
(*tn)->next= NULL;
(*tn)->v[LEFT]= NULL;
(*tn)->v[RIGHT]= NULL;
(*tn)->active= 1;
add_vertex(&((*tn)->v[LEFT]), x, y);
edge->outp[ABOVE]= *tn;
else
new_tristrip(&((*tn)->next), edge, x, y);
static bbox *create_contour_bboxes(gpc_polygon *p)
bbox *box;
int c, v;
MALLOC(box, p->num_contours * sizeof(bbox), "Bounding box creation");
/* Construct contour bounding boxes */
/* Initialise bounding box extent */
box[c].xmin= DBL_MAX;
box[c].ymin= DBL_MAX;
box[c].xmax= -DBL_MAX;
box[c].ymax= -DBL_MAX;
for (v= 0; v < p->contour[c].num_vertices; v++)
/* Adjust bounding box */
if (p->contour[c].vertex[v].x < box[c].xmin)
box[c].xmin= p->contour[c].vertex[v].x;
if (p->contour[c].vertex[v].y < box[c].ymin)
box[c].ymin= p->contour[c].vertex[v].y;
if (p->contour[c].vertex[v].x > box[c].xmax)
box[c].xmax= p->contour[c].vertex[v].x;
if (p->contour[c].vertex[v].y > box[c].ymax)
box[c].ymax= p->contour[c].vertex[v].y;
return box;
static void minimax_test(gpc_polygon *subj, gpc_polygon *clip, gpc_op op)
bbox *s_bbox, *c_bbox;
int s, c, *o_table, overlap;
s_bbox= create_contour_bboxes(subj);
c_bbox= create_contour_bboxes(clip);
MALLOC(o_table, subj->num_contours * clip->num_contours * sizeof(int),
"overlap table creation");
/* Check all subject contour bounding boxes against clip boxes */
for (s= 0; s < subj->num_contours; s++)
for (c= 0; c < clip->num_contours; c++)
o_table[c * subj->num_contours + s]=
(!((s_bbox[s].xmax < c_bbox[c].xmin) ||
(s_bbox[s].xmin > c_bbox[c].xmax))) &&
(!((s_bbox[s].ymax < c_bbox[c].ymin) ||
(s_bbox[s].ymin > c_bbox[c].ymax)));
/* For each clip contour, search for any subject contour overlaps */
overlap= 0;
for (s= 0; (!overlap) && (s < subj->num_contours); s++)
overlap= o_table[c * subj->num_contours + s];
if (!overlap)
/* Flag non contributing status by negating vertex count */
clip->contour[c].num_vertices = -clip->contour[c].num_vertices;
if (op == GPC_INT)
/* For each subject contour, search for any clip contour overlaps */
overlap= 0;
for (c= 0; (!overlap) && (c < clip->num_contours); c++)
if (!overlap)
subj->contour[s].num_vertices = -subj->contour[s].num_vertices;
FREE(s_bbox);
FREE(c_bbox);
FREE(o_table);
Public Functions
void gpc_free_polygon(gpc_polygon *p)
int c;
FREE(p->contour[c].vertex);
FREE(p->hole);
FREE(p->contour);
p->num_contours= 0;
void gpc_read_polygon(FILE *fp, int read_hole_flags, gpc_polygon *p)
int c, v;
fscanf(fp, "%d", &(p->num_contours));
MALLOC(p->hole, p->num_contours * sizeof(int),
"hole flag array creation");
MALLOC(p->contour, p->num_contours
* sizeof(gpc_vertex_list), "contour creation");
fscanf(fp, "%d", &(p->contour[c].num_vertices));
if (read_hole_flags)
fscanf(fp, "%d", &(p->hole[c]));
else
p->hole[c]= FALSE; /* Assume all contours to be external */
MALLOC(p->contour[c].vertex, p->contour[c].num_vertices
* sizeof(gpc_vertex), "vertex creation");
fscanf(fp, "%lf %lf", &(p->contour[c].vertex[v].x),
&(p->contour[c].vertex[v].y));
void gpc_write_polygon(FILE *fp, int write_hole_flags, gpc_polygon *p)
int c, v;
fprintf(fp, "%d\n", p->num_contours);
fprintf(fp, "%d\n", p->contour[c].num_vertices);
if (write_hole_flags)
fprintf(fp, "%d\n", p->hole[c]);
fprintf(fp, "% .*lf % .*lf\n",
DBL_DIG, p->contour[c].vertex[v].x,
DBL_DIG, p->contour[c].vertex[v].y);
void gpc_add_contour(gpc_polygon *p, gpc_vertex_list *new_contour, int hole)
int *extended_hole, c, v;
gpc_vertex_list *extended_contour;
/* Create an extended hole array */
MALLOC(extended_hole, (p->num_contours + 1)
* sizeof(int), "contour hole addition");
/* Create an extended contour array */
MALLOC(extended_contour, (p->num_contours + 1)
* sizeof(gpc_vertex_list), "contour addition");
/* Copy the old contour and hole data into the extended arrays */
extended_hole[c]= p->hole[c];
extended_contour[c]= p->contour[c];
/* Copy the new contour and hole onto the end of the extended arrays */
c= p->num_contours;
extended_hole[c]= hole;
extended_contour[c].num_vertices= new_contour->num_vertices;
MALLOC(extended_contour[c].vertex, new_contour->num_vertices
* sizeof(gpc_vertex), "contour addition");
for (v= 0; v < new_contour->num_vertices; v++)
extended_contour[c].vertex[v]= new_contour->vertex[v];
/* Dispose of the old contour */
FREE(p->contour);
FREE(p->hole);
/* Update the polygon information */
p->num_contours++;
p->hole= extended_hole;
p->contour= extended_contour;
void gpc_polygon_clip(gpc_op op, gpc_polygon *subj, gpc_polygon *clip,
gpc_polygon *result)
sb_tree *sbtree= NULL;
it_node *it= NULL, *intersect;
edge_node *edge, *prev_edge, *next_edge, *succ_edge, *e0, *e1;
edge_node *aet= NULL, *c_heap= NULL, *s_heap= NULL;
lmt_node *lmt= NULL, *local_min;
polygon_node *out_poly= NULL, *p, *q, *poly, *npoly, *cf= NULL;
vertex_node *vtx, *nv;
h_state horiz[2];
int in[2], exists[2], parity[2]= {LEFT, LEFT};
int c, v, contributing, search, scanbeam= 0, sbt_entries= 0;
int vclass, bl, br, tl, tr;
double *sbt= NULL, xb, px, yb, yt, dy, ix, iy;
/* Test for trivial NULL result cases */
if (((subj->num_contours == 0) && (clip->num_contours == 0))
|| ((subj->num_contours == 0) && ((op == GPC_INT) || (op == GPC_DIFF)))
|| ((clip->num_contours == 0) && (op == GPC_INT)))
result->num_contours= 0;
result->hole= NULL;
result->contour= NULL;
return;
/* Identify potentialy contributing contours */
if (((op == GPC_INT) || (op == GPC_DIFF))
&& (subj->num_contours > 0) && (clip->num_contours > 0))
minimax_test(subj, clip, op);
/* Build LMT */
if (subj->num_contours > 0)
s_heap= build_lmt(&lmt, &sbtree, &sbt_entries, subj, SUBJ, op);
if (clip->num_contours > 0)
c_heap= build_lmt(&lmt, &sbtree, &sbt_entries, clip, CLIP, op);
/* Return a NULL result if no contours contribute */
if (lmt == NULL)
result->hole= NULL;
reset_lmt(&lmt);
FREE(s_heap);
FREE(c_heap);
return;
/* Build scanbeam table from scanbeam tree */
MALLOC(sbt, sbt_entries * sizeof(double), "sbt creation");
build_sbt(&scanbeam, sbt, sbtree);
scanbeam= 0;
free_sbtree(&sbtree);
/* Allow pointer re-use without causing memory leak */
if (subj == result)
gpc_free_polygon(subj);
if (clip == result)
gpc_free_polygon(clip);
/* Invert clip polygon for difference operation */
if (op == GPC_DIFF)
parity[CLIP]= RIGHT;
local_min= lmt;
/* Process each scanbeam */
while (scanbeam < sbt_entries)
/* Set yb and yt to the bottom and top of the scanbeam */
yb= sbt[scanbeam++];
if (scanbeam < sbt_entries)
yt= sbt[scanbeam];
dy= yt - yb;
/* === SCANBEAM BOUNDARY PROCESSING ================================ */
/* If LMT node corresponding to yb exists */
if (local_min)
if (local_min->y == yb)
/* Add edges starting at this local minimum to the AET */
for (edge= local_min->first_bound; edge; edge= edge->next_bound)
add_edge_to_aet(&aet, edge, NULL);
local_min= local_min->next;
/* Set dummy previous x value */
px= -DBL_MAX;
/* Create bundles within AET */
e0= aet;
e1= aet;
/* Set up bundle fields of first edge */
aet->bundle[ABOVE][ aet->type]= (aet->top.y != yb);
aet->bundle[ABOVE][!aet->type]= FALSE;
aet->bstate[ABOVE]= UNBUNDLED;
for (next_edge= aet->next; next_edge; next_edge= next_edge->next)
/* Set up bundle fields of next edge */
next_edge->bundle[ABOVE][ next_edge->type]= (next_edge->top.y != yb);
next_edge->bundle[ABOVE][!next_edge->type]= FALSE;
next_edge->bstate[ABOVE]= UNBUNDLED;
/* Bundle edges above the scanbeam boundary if they coincide */
if (next_edge->bundle[ABOVE][next_edge->type])
if (EQ(e0->xb, next_edge->xb) && EQ(e0->dx, next_edge->dx)
&& (e0->top.y != yb))
next_edge->bundle[ABOVE][ next_edge->type]^=
e0->bundle[ABOVE][ next_edge->type];
e0->bundle[ABOVE][!next_edge->type];
next_edge->bstate[ABOVE]= BUNDLE_HEAD;
e0->bundle[ABOVE][CLIP]= FALSE;
e0->bundle[ABOVE][SUBJ]= FALSE;
e0->bstate[ABOVE]= BUNDLE_TAIL;
e0= next_edge;
horiz[CLIP]= NH;
horiz[SUBJ]= NH;
/* Process each edge at this scanbeam boundary */
exists[CLIP]= edge->bundle[ABOVE][CLIP] +
(edge->bundle[BELOW][CLIP] << 1);
exists[SUBJ]= edge->bundle[ABOVE][SUBJ] +
(edge->bundle[BELOW][SUBJ] << 1);
if (exists[CLIP] || exists[SUBJ])
/* Set bundle side */
edge->bside[CLIP]= parity[CLIP];
edge->bside[SUBJ]= parity[SUBJ];
/* Determine contributing status and quadrant occupancies */
switch (op)
case GPC_DIFF:
case GPC_INT:
contributing= (exists[CLIP] && (parity[SUBJ] || horiz[SUBJ]))
|| (exists[SUBJ] && (parity[CLIP] || horiz[CLIP]))
|| (exists[CLIP] && exists[SUBJ]
&& (parity[CLIP] == parity[SUBJ]));
br= (parity[CLIP])
&& (parity[SUBJ]);
bl= (parity[CLIP] ^ edge->bundle[ABOVE][CLIP])
&& (parity[SUBJ] ^ edge->bundle[ABOVE][SUBJ]);
tr= (parity[CLIP] ^ (horiz[CLIP]!=NH))
&& (parity[SUBJ] ^ (horiz[SUBJ]!=NH));
tl= (parity[CLIP] ^ (horiz[CLIP]!=NH) ^ edge->bundle[BELOW][CLIP])
&& (parity[SUBJ] ^ (horiz[SUBJ]!=NH) ^ edge->bundle[BELOW][SUBJ]);
break;
case GPC_XOR:
contributing= exists[CLIP] || exists[SUBJ];
br= (parity[CLIP])
^ (parity[SUBJ]);
^ (parity[SUBJ] ^ edge->bundle[ABOVE][SUBJ]);
^ (parity[SUBJ] ^ (horiz[SUBJ]!=NH));
^ (parity[SUBJ] ^ (horiz[SUBJ]!=NH) ^ edge->bundle[BELOW][SUBJ]);
break;
case GPC_UNION:
contributing= (exists[CLIP] && (!parity[SUBJ] || horiz[SUBJ]))
|| (exists[SUBJ] && (!parity[CLIP] || horiz[CLIP]))
br= (parity[CLIP])
|| (parity[SUBJ]);
break;
/* Update parity */
parity[CLIP]^= edge->bundle[ABOVE][CLIP];
parity[SUBJ]^= edge->bundle[ABOVE][SUBJ];
/* Update horizontal state */
if (exists[CLIP])
horiz[CLIP]=
next_h_state[horiz[CLIP]]
[((exists[CLIP] - 1) << 1) + parity[CLIP]];
if (exists[SUBJ])
horiz[SUBJ]=
next_h_state[horiz[SUBJ]]
[((exists[SUBJ] - 1) << 1) + parity[SUBJ]];
vclass= tr + (tl << 1) + (br << 2) + (bl << 3);
if (contributing)
xb= edge->xb;
switch (vclass)
case EMN:
case IMN:
add_local_min(&out_poly, edge, xb, yb);
px= xb;
cf= edge->outp[ABOVE];
break;
case ERI:
if (xb != px)
add_right(cf, xb, yb);
px= xb;
edge->outp[ABOVE]= cf;
cf= NULL;
break;
case ELI:
add_left(edge->outp[BELOW], xb, yb);
px= xb;
cf= edge->outp[BELOW];
break;
case EMX:
if (xb != px)
add_left(cf, xb, yb);
px= xb;
merge_right(cf, edge->outp[BELOW], out_poly);
cf= NULL;
break;
case ILI:
if (xb != px)
px= xb;
cf= NULL;
break;
case IRI:
add_right(edge->outp[BELOW], xb, yb);
px= xb;
edge->outp[BELOW]= NULL;
break;
case IMX:
if (xb != px)
px= xb;
merge_left(cf, edge->outp[BELOW], out_poly);
cf= NULL;
break;
case IMM:
if (xb != px)
px= xb;
break;
case EMM:
if (xb != px)
px= xb;
break;
case LED:
if (edge->bot.y == yb)
edge->outp[ABOVE]= edge->outp[BELOW];
px= xb;
break;
case RED:
px= xb;
break;
default:
break;
} /* End of switch */
} /* End of contributing conditional */
} /* End of edge exists conditional */
} /* End of AET loop */
/* Delete terminating edges from the AET, otherwise compute xt */
if (edge->top.y == yb)
prev_edge= edge->prev;
next_edge= edge->next;
if (prev_edge)
prev_edge->next= next_edge;
else
aet= next_edge;
if (next_edge)
next_edge->prev= prev_edge;
/* Copy bundle head state to the adjacent tail edge if required */
if ((edge->bstate[BELOW] == BUNDLE_HEAD) && prev_edge)
if (prev_edge->bstate[BELOW] == BUNDLE_TAIL)
prev_edge->outp[BELOW]= edge->outp[BELOW];
prev_edge->bstate[BELOW]= UNBUNDLED;
if (prev_edge->prev)
if (prev_edge->prev->bstate[BELOW] == BUNDLE_TAIL)
prev_edge->bstate[BELOW]= BUNDLE_HEAD;
else
if (edge->top.y == yt)
edge->xt= edge->top.x;
else
edge->xt= edge->bot.x + edge->dx * (yt - edge->bot.y);
/* === SCANBEAM INTERIOR PROCESSING ============================== */
build_intersection_table(&it, aet, dy);
/* Process each node in the intersection table */
for (intersect= it; intersect; intersect= intersect->next)
e0= intersect->ie[0];
e1= intersect->ie[1];
/* Only generate output for contributing intersections */
if ((e0->bundle[ABOVE][CLIP] || e0->bundle[ABOVE][SUBJ])
&& (e1->bundle[ABOVE][CLIP] || e1->bundle[ABOVE][SUBJ]))
p= e0->outp[ABOVE];
q= e1->outp[ABOVE];
ix= intersect->point.x;
iy= intersect->point.y + yb;
in[CLIP]= ( e0->bundle[ABOVE][CLIP] && !e0->bside[CLIP])
|| ( e1->bundle[ABOVE][CLIP] && e1->bside[CLIP])
|| (!e0->bundle[ABOVE][CLIP] && !e1->bundle[ABOVE][CLIP]
&& e0->bside[CLIP] && e1->bside[CLIP]);
in[SUBJ]= ( e0->bundle[ABOVE][SUBJ] && !e0->bside[SUBJ])
|| ( e1->bundle[ABOVE][SUBJ] && e1->bside[SUBJ])
|| (!e0->bundle[ABOVE][SUBJ] && !e1->bundle[ABOVE][SUBJ]
&& e0->bside[SUBJ] && e1->bside[SUBJ]);
/* Determine quadrant occupancies */
switch (op)
case GPC_DIFF:
case GPC_INT:
tr= (in[CLIP])
&& (in[SUBJ]);
tl= (in[CLIP] ^ e1->bundle[ABOVE][CLIP])
&& (in[SUBJ] ^ e1->bundle[ABOVE][SUBJ]);
br= (in[CLIP] ^ e0->bundle[ABOVE][CLIP])
&& (in[SUBJ] ^ e0->bundle[ABOVE][SUBJ]);
bl= (in[CLIP] ^ e1->bundle[ABOVE][CLIP] ^ e0->bundle[ABOVE][CLIP])
&& (in[SUBJ] ^ e1->bundle[ABOVE][SUBJ] ^ e0->bundle[ABOVE][SUBJ]);
break;
case GPC_XOR:
tr= (in[CLIP])
^ (in[SUBJ]);
^ (in[SUBJ] ^ e1->bundle[ABOVE][SUBJ]);
^ (in[SUBJ] ^ e0->bundle[ABOVE][SUBJ]);
^ (in[SUBJ] ^ e1->bundle[ABOVE][SUBJ] ^ e0->bundle[ABOVE][SUBJ]);
break;
case GPC_UNION:
tr= (in[CLIP])
|| (in[SUBJ]);
break;
switch (vclass)
case EMN:
add_local_min(&out_poly, e0, ix, iy);
e1->outp[ABOVE]= e0->outp[ABOVE];
break;
case ERI:
if (p)
add_right(p, ix, iy);
e1->outp[ABOVE]= p;
e0->outp[ABOVE]= NULL;
break;
case ELI:
if (q)
add_left(q, ix, iy);
e0->outp[ABOVE]= q;
e1->outp[ABOVE]= NULL;
break;
case EMX:
if (p && q)
add_left(p, ix, iy);
merge_right(p, q, out_poly);
break;
case IMN:
break;
case ILI:
if (p)
e1->outp[ABOVE]= p;
break;
case IRI:
if (q)
add_right(q, ix, iy);
e0->outp[ABOVE]= q;
break;
case IMX:
if (p && q)
merge_left(p, q, out_poly);
break;
case IMM:
if (p && q)
break;
case EMM:
if (p && q)
break;
default:
break;
} /* End of contributing intersection conditional */
/* Swap bundle sides in response to edge crossing */
if (e0->bundle[ABOVE][CLIP])
e1->bside[CLIP]= !e1->bside[CLIP];
if (e1->bundle[ABOVE][CLIP])
e0->bside[CLIP]= !e0->bside[CLIP];
if (e0->bundle[ABOVE][SUBJ])
e1->bside[SUBJ]= !e1->bside[SUBJ];
if (e1->bundle[ABOVE][SUBJ])
e0->bside[SUBJ]= !e0->bside[SUBJ];
/* Swap e0 and e1 bundles in the AET */
prev_edge= e0->prev;
next_edge= e1->next;
if (next_edge)
next_edge->prev= e0;
if (e0->bstate[ABOVE] == BUNDLE_HEAD)
search= TRUE;
while (search)
prev_edge= prev_edge->prev;
if (prev_edge)
if (prev_edge->bstate[ABOVE] != BUNDLE_TAIL)
search= FALSE;
else
search= FALSE;
if (!prev_edge)
aet->prev= e1;
e1->next= aet;
aet= e0->next;
else
prev_edge->next->prev= e1;
e1->next= prev_edge->next;
prev_edge->next= e0->next;
e0->next->prev= prev_edge;
e1->next->prev= e1;
e0->next= next_edge;
} /* End of IT loop*/
/* Prepare for next scanbeam */
for (edge= aet; edge; edge= next_edge)
succ_edge= edge->succ;
if ((edge->top.y == yt) && succ_edge)
/* Replace AET edge by its successor */
succ_edge->outp[BELOW]= edge->outp[ABOVE];
succ_edge->bstate[BELOW]= edge->bstate[ABOVE];
succ_edge->bundle[BELOW][CLIP]= edge->bundle[ABOVE][CLIP];
succ_edge->bundle[BELOW][SUBJ]= edge->bundle[ABOVE][SUBJ];
if (prev_edge)
prev_edge->next= succ_edge;
else
aet= succ_edge;
if (next_edge)
next_edge->prev= succ_edge;
succ_edge->prev= prev_edge;
succ_edge->next= next_edge;
else
/* Update this edge */
edge->xb= edge->xt;
edge->outp[ABOVE]= NULL;
} /* === END OF SCANBEAM PROCESSING ================================== */
/* Generate result polygon from out_poly */
result->hole= NULL;
result->num_contours= count_contours(out_poly);
if (result->num_contours > 0)
MALLOC(result->hole, result->num_contours
* sizeof(int), "hole flag table creation");
MALLOC(result->contour, result->num_contours
c= 0;
for (poly= out_poly; poly; poly= npoly)
npoly= poly->next;
if (poly->active)
result->hole[c]= poly->proxy->hole;
result->contour[c].num_vertices= poly->active;
MALLOC(result->contour[c].vertex,
result->contour[c].num_vertices * sizeof(gpc_vertex),
"vertex creation");
v= result->contour[c].num_vertices - 1;
for (vtx= poly->proxy->v[LEFT]; vtx; vtx= nv)
nv= vtx->next;
result->contour[c].vertex[v].x= vtx->x;
result->contour[c].vertex[v].y= vtx->y;
FREE(vtx);
v--;
c++;
FREE(poly);
/* Tidy up */
reset_it(&it);
reset_lmt(&lmt);
FREE(c_heap);
FREE(s_heap);
FREE(sbt);
void gpc_free_tristrip(gpc_tristrip *t)
int s;
for (s= 0; s < t->num_strips; s++)
FREE(t->strip[s].vertex);
FREE(t->strip);
t->num_strips= 0;
void gpc_polygon_to_tristrip(gpc_polygon *s, gpc_tristrip *t)
gpc_polygon c;
c.num_contours= 0;
c.hole= NULL;
c.contour= NULL;
gpc_tristrip_clip(GPC_DIFF, s, &c, t);
void gpc_tristrip_clip(gpc_op op, gpc_polygon *subj, gpc_polygon *clip,
gpc_tristrip *result)
edge_node *aet= NULL, *c_heap= NULL, *s_heap= NULL, *cf;
polygon_node *tlist= NULL, *tn, *tnn, *p, *q;
vertex_node *lt, *ltn, *rt, *rtn;
h_state horiz[2];
vertex_type cft;
int s, v, contributing, search, scanbeam= 0, sbt_entries= 0;
double *sbt= NULL, xb, px, nx, yb, yt, dy, ix, iy;
result->num_strips= 0;
result->strip= NULL;
return;
/* Build LMT */
if (lmt == NULL)
reset_lmt(&lmt);
FREE(s_heap);
FREE(c_heap);
return;
scanbeam= 0;
if (op == GPC_DIFF)
local_min= lmt;
yt= sbt[scanbeam];
dy= yt - yb;
if (local_min)
px= -DBL_MAX;
e0= aet;
e1= aet;
e0= next_edge;
horiz[CLIP]= NH;
horiz[SUBJ]= NH;
switch (op)
case GPC_DIFF:
case GPC_INT:
br= (parity[CLIP])
&& (parity[SUBJ]);
break;
case GPC_XOR:
br= (parity[CLIP])
^ (parity[SUBJ]);
break;
case GPC_UNION:
br= (parity[CLIP])
|| (parity[SUBJ]);
break;
/* Update parity */
if (exists[CLIP])
horiz[CLIP]=
if (exists[SUBJ])
horiz[SUBJ]=
if (contributing)
xb= edge->xb;
switch (vclass)
case EMN:
new_tristrip(&tlist, edge, xb, yb);
cf= edge;
break;
case ERI:
edge->outp[ABOVE]= cf->outp[ABOVE];
if (xb != cf->xb)
VERTEX(edge, ABOVE, RIGHT, xb, yb);
cf= NULL;
break;
case ELI:
VERTEX(edge, BELOW, LEFT, xb, yb);
cf= edge;
break;
case EMX:
if (xb != cf->xb)
VERTEX(edge, BELOW, RIGHT, xb, yb);
cf= NULL;
break;
case IMN:
if (cft == LED)
if (cf->bot.y != yb)
VERTEX(cf, BELOW, LEFT, cf->xb, yb);
new_tristrip(&tlist, cf, cf->xb, yb);
break;
case ILI:
cf= edge;
cft= ILI;
break;
case IRI:
if (cft == LED)
break;
case IMX:
cft= IMX;
break;
case IMM:
if (xb != cf->xb)
VERTEX(cf, ABOVE, RIGHT, xb, yb);
cf= edge;
break;
case EMM:
cf= edge;
break;
case LED:
cf= edge;
cft= LED;
break;
case RED:
if (cft == LED)
if (cf->bot.y == yb)
else
else
cf= NULL;
break;
default:
break;
if (prev_edge)
else
aet= next_edge;
if (next_edge)
else
else
p= e0->outp[ABOVE];
q= e1->outp[ABOVE];
switch (op)
case GPC_DIFF:
case GPC_INT:
tr= (in[CLIP])
&& (in[SUBJ]);
break;
case GPC_XOR:
tr= (in[CLIP])
^ (in[SUBJ]);
break;
case GPC_UNION:
tr= (in[CLIP])
|| (in[SUBJ]);
break;
switch (vclass)
case EMN:
new_tristrip(&tlist, e1, ix, iy);
e0->outp[ABOVE]= e1->outp[ABOVE];
break;
case ERI:
if (p)
P_EDGE(prev_edge, e0, ABOVE, px, iy);
VERTEX(prev_edge, ABOVE, LEFT, px, iy);
VERTEX(e0, ABOVE, RIGHT, ix, iy);
break;
case ELI:
if (q)
N_EDGE(next_edge, e1, ABOVE, nx, iy);
VERTEX(e1, ABOVE, LEFT, ix, iy);
VERTEX(next_edge, ABOVE, RIGHT, nx, iy);
break;
case EMX:
if (p && q)
VERTEX(e0, ABOVE, LEFT, ix, iy);
break;
case IMN:
new_tristrip(&tlist, prev_edge, px, iy);
e1->outp[ABOVE]= prev_edge->outp[ABOVE];
VERTEX(e1, ABOVE, RIGHT, ix, iy);
new_tristrip(&tlist, e0, ix, iy);
next_edge->outp[ABOVE]= e0->outp[ABOVE];
break;
case ILI:
if (p)
break;
case IRI:
if (q)
break;
case IMX:
if (p && q)
next_edge->outp[ABOVE]= prev_edge->outp[ABOVE];
break;
case IMM:
if (p && q)
break;
case EMM:
if (p && q)
break;
default:
break;
if (e1->next)
e1->next->prev= e0;
search= TRUE;
while (search)
if (prev_edge)
if (prev_edge->bundle[ABOVE][CLIP]
|| prev_edge->bundle[ABOVE][SUBJ]
|| (prev_edge->bstate[ABOVE] == BUNDLE_HEAD))
search= FALSE;
else
search= FALSE;
if (!prev_edge)
e1->next= aet;
aet= e0->next;
else
e1->next->prev= e1;
if (prev_edge)
else
aet= succ_edge;
if (next_edge)
else
edge->xb= edge->xt;
/* Generate result tristrip from tlist */
result->num_strips= count_tristrips(tlist);
if (result->num_strips > 0)
MALLOC(result->strip, result->num_strips * sizeof(gpc_vertex_list),
"tristrip list creation");
s= 0;
for (tn= tlist; tn; tn= tnn)
tnn= tn->next;
if (tn->active > 2)
/* Valid tristrip: copy the vertices and free the heap */
result->strip[s].num_vertices= tn->active;
MALLOC(result->strip[s].vertex, tn->active * sizeof(gpc_vertex),
"tristrip creation");
v= 0;
if (INVERT_TRISTRIPS)
lt= tn->v[RIGHT];
rt= tn->v[LEFT];
else
lt= tn->v[LEFT];
rt= tn->v[RIGHT];
while (lt || rt)
if (lt)
ltn= lt->next;
result->strip[s].vertex[v].x= lt->x;
result->strip[s].vertex[v].y= lt->y;
v++;
FREE(lt);
lt= ltn;
if (rt)
rtn= rt->next;
result->strip[s].vertex[v].x= rt->x;
result->strip[s].vertex[v].y= rt->y;
v++;
FREE(rt);
rt= rtn;
s++;
else
/* Invalid tristrip: just free the heap */
for (lt= tn->v[LEFT]; lt; lt= ltn)
ltn= lt->next;
FREE(lt);
for (rt= tn->v[RIGHT]; rt; rt=rtn)
rtn= rt->next;
FREE(rt);
FREE(tn);
/* Tidy up */
reset_it(&it);
reset_lmt(&lmt);
FREE(c_heap);
FREE(s_heap);
FREE(sbt);
End of file: gpc.c
-- Selected TOC Entries:
\connect - postgres
-- TOC Entry ID 2 (OID 922575)
-- Name: testgpc Type: TABLE Owner: postgres
CREATE TABLE "testgpc" (
"id" integer,
"geom" geometry
-- Data for TOC Entry ID 3 (OID 922575)
-- Name: testgpc Type: TABLE DATA Owner: postgres
COPY "testgpc" FROM stdin;
1 SRID=-1;POLYGON((1 1,3 1,3 3,1 1))
2 SRID=-1;POLYGON((2 1,2 3,1 3,2 1))
3 SRID=-1;POLYGON((3 2,10 2,10 6,8 6,8 3,5 3,5 6,3 6,3 2),(4.5 4.5,4.5 5,3.5 5,3.5 4.5,4.5 4.5),(9.5 4.5,9.5 5,8.5 5,8.5 4.5,9.5 4.5))
4 SRID=-1;POLYGON((12 4,12 8,1 8,1 4,12 4))
5 SRID=-1;POLYGON((9 5,9 7.5,6.5 7.5,6.5 5,9 5),(8.5 5,8.5 7,7 7,8.5 5))
