[postgis-users] error executing psql -d mydb -f postgis.sql
Tyler Mitchell
TMitchell at lignum.com
Thu Aug 1 08:24:31 PDT 2002
Mr. P wrote:
>Do the postgres steps as the 'postgres' user, for maximum cleanliness.
>The 'postgres' user is the pgsql equivalent of root.
So you would do all the steps I mentioned as the postgres user?
>>Tyler Mitchell wrote:
>> I'm not sure I follow exactly, but I've had lots of grief running
>> postgis.sql in the past...but now I understand enough to get it working
>> fine! So be encouraged. The biggest mistake I was making, or the thing
I
>> found helped the most was being logged in as the same user for all
steps:
>> -createdb
>> -createlang
>> -and the psql -f postgis.sql step too.
>> I'm usually doing it as root, but I don't think you need to. Give it a
>> try: create a new db, etc. and see if it works for you.
Paul Ramsey
<pramsey at refractions.net> To: postgis-users at postgis.refractions.net
Sent by: cc:
postgis-users-admin at postgis.refr Fax to:
actions.net Subject: Re: [postgis-users] error executing psql -d mydb
-f postgis.sql
08/01/2002 08:22 AM
Please respond to postgis-users
I
> found helped the most was being logged in as the same user for all steps:
> -createdb
> -createlang
> Tyler
> root <porfidia at anpa.it>
> Sent by: To:
> postgis-users-admin at postgis.refr cc:
> actions.net Fax to:
> Subject:
postgis.sql
> 08/01/2002 08:04 AM
> Hi all
> I'm newby of the list and postgis too
> I installed Postgis on postgresql 7.2.1 (default installation from
> tarball) and Red Hat7.2 and all worked fine till the command psql.......
> It gives me this error
> I took postgis.sql file from
> /usr/local/pgsql/share/contrib/postgis.sql and
> in /usr/local/pgsql/bin I made ./psql -d mydb -f
> /usr/local/share/contrib/postgis.sql as postgres user
> BEGIN
> psql:/usr/local/pgsql/share/contrib/postgis.sql:772: ERROR: argument
> type geometry does not exist
> psql:/usr/local/pgsql/share/contrib/postgis.sql:775: NOTICE: current
> transaction is aborted, queries ignored until end of transaction block
> *ABORT STATE*
> and at the end
> psql:/usr/local/pgsql/share/contrib/postgis.sql:1026: NOTICE: current
> *ABORT STATE*
> COMMIT
> thus I checked all permissions and chown to postgres user
> I tried 0.7.1 dist and cvs snapshot dist but nothing change
> Anybody can help me
> Am i wrong
> Am I right
> oohh my god what have I done?
> postgis-users mailing list
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
