[postgis-users] error executing psql -d mydb -f postgis.sql
Paul Ramsey
pramsey at refractions.net
Thu Aug 1 08:28:11 PDT 2002
Yes. The postgis.sql script for example adds types, which is a
'superuser only' process, and the postgres user is guaranteed to be able
to do that.
Tyler Mitchell wrote:
> Mr. P wrote:
> >Do the postgres steps as the 'postgres' user, for maximum cleanliness.
> >The 'postgres' user is the pgsql equivalent of root.
> So you would do all the steps I mentioned as the postgres user?
> >> I'm not sure I follow exactly, but I've had lots of grief running
> >> postgis.sql in the past...but now I understand enough to get it working
> >> fine! So be encouraged. The biggest mistake I was making, or the thing
> I
> >> found helped the most was being logged in as the same user for all
> steps:
> >> -createdb
> >> -createlang
> >> -and the psql -f postgis.sql step too.
> >> I'm usually doing it as root, but I don't think you need to. Give it a
> >> try: create a new db, etc. and see if it works for you.
> Paul Ramsey
> <pramsey at refractions.net> To: postgis-users at postgis.refractions.net
> Sent by: cc:
> postgis-users-admin at postgis.refr Fax to:
> actions.net Subject: Re: [postgis-users] error executing psql -d mydb
> -f postgis.sql
> 08/01/2002 08:22 AM
> Please respond to postgis-users
> I
> > found helped the most was being logged in as the same user for all steps:
> > -createdb
> > -createlang
> > Tyler
> > root <porfidia at anpa.it>
> > Sent by: To:
> > postgis-users-admin at postgis.refr cc:
> > actions.net Fax to:
> > Subject:
> postgis.sql
> > 08/01/2002 08:04 AM
> > Hi all
> > I'm newby of the list and postgis too
> > I installed Postgis on postgresql 7.2.1 (default installation from
> > tarball) and Red Hat7.2 and all worked fine till the command psql.......
> > It gives me this error
> > I took postgis.sql file from
> > /usr/local/pgsql/share/contrib/postgis.sql and
> > in /usr/local/pgsql/bin I made ./psql -d mydb -f
> > /usr/local/share/contrib/postgis.sql as postgres user
> > BEGIN
> > psql:/usr/local/pgsql/share/contrib/postgis.sql:772: ERROR: argument
> > type geometry does not exist
> > psql:/usr/local/pgsql/share/contrib/postgis.sql:775: NOTICE: current
> > transaction is aborted, queries ignored until end of transaction block
> > *ABORT STATE*
> > and at the end
> > psql:/usr/local/pgsql/share/contrib/postgis.sql:1026: NOTICE: current
> > *ABORT STATE*
> > COMMIT
> > thus I checked all permissions and chown to postgres user
> > I tried 0.7.1 dist and cvs snapshot dist but nothing change
> > Anybody can help me
> > Am i wrong
> > Am I right
> > oohh my god what have I done?
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
__
| Paul Ramsey
\_
