[postgis-users] shp2pgsql Segmentation fault
Steffen Macke
sdteffen at web.de
Fri Aug 9 03:17:55 PDT 2002
On Friday 09 August 2002 13:50, Düster Horst wrote:
> The next problem. During the import of the attached shape the process
> crashes with Segmentation fault. I can't discover any problem within the
> shape. ArcView is able to handle the shape.
> shp2pgsql -d -D test.shp test DBName | psql -d DBName
I was able to import the file without any problems.
I'll send Horst the sql separately. He can then diff the files to see if
his shp2pgsql does something different
Steffen
