[postgis-users] postgis connection problem
Chris Hodgson
chodgson at refractions.net
Fri Aug 9 09:15:19 PDT 2002
This is telling you that there is an error in your string on line 4 - most
likely you need to quote the NAME of your layer.
Chris
----- Original Message -----
To: <postgis-users at postgis.refractions.net>
Sent: Friday, August 09, 2002 8:44 AM
Subject: [postgis-users] postgis connection problem
> Hi
> I tried shp2img mapserver command and it returned this error
> [root at porfidia mapserver-3.6.1]# ./shp2img -m /var/www/postgis.map -o
> pippo
> getString(): Symbol definition error. (Postgis):(4)
> I haven't any pwd for postgres user on db
> but I compiled mapserver as root with /usr/local prefix it installed in
> current dir
> so I trid to run shp2img as postgres but he can't obviously
> I tried shp2img with another mapfile without postgis and it work fine.
> benedetto
> postgis-users mailing list
