[postgis-users] Problem finding intersection of LineString and BOX3D?
Dave Blasby
dblasby at refractions.net
Tue Aug 13 09:46:02 PDT 2002
Mark Cave-Ayland wrote:
> Thanks for your reply. I tried your new select statement but it doesn't work
> for lines at all :( It would be useful to get the cohen-sutherland algorithm
> working as it seems really fast - what's the easiest way to step through the
> routine while it tests a linestring?
Oops, forgot to convert the bounding box to a polygon - use the
envelope() function.
SELECT name FROM linetesttab WHERE geom &&
setSRID('BOX3D(247531.5250251
52556.353020652,247567.13124875 52591.959244305)'::BOX3D,
find_srid('','linetesttab','geom') ) AND distance(geom,
envelope(setSRID('BOX3D(247531.5250251 52556.353020652,247567.13124875
52591.959244305)'::BOX3D, find_srid('', 'linetesttab', 'geom')))) =0
I havent looked at the C-S for a while, but there are references online
for
it.
Basically, it works by subdividing space based 2 horizontal and 2
verticle lines that make up the box. Codes are assigning
to the various sub-spaces:
// 1001 | 1000 | 1010
// | (inside) |
// 0001 | | 0010
// | 0000 |
// 0101 | 0100 | 0110
You'll see that everything above the box starts with a "1---" and
everything to the left of the box looks like "---1".
These codes will help us to quickly determine if a line segment is
inside the box.
The algo (for lines) looks like:
For each line segment (2 points) DO
Compute codes for both points
IF Code0 = 0000 or Code1=0000 THEN truly inside
IF Code0 & Code1 != 0 THEN not truly inside
IF otherwise have to do the hard math to see if the
line segment does pass through the box
If "Code0 & Code1 != 0" then the two points are on the same half-plane
and CANNOT intersect the box.
The problem with the code is probably in the function
lineseg_inside_box().
You should be able to find lots of references to the cohen-sutherland
algorithm online (or in any graphics textbook), and your simple test
case should find out whats wrong very quickly!!
dave
