[postgis-users] PostGIS vs Suse8.0
Tyler Mitchell
themitchells at telus.net
Mon Aug 19 07:49:53 PDT 2002
From what I understand, you do not need to recompile postgresql from source,
but youdo need to have the source code available in order to build postgis.
Should be doable for you!
Tyler
-----Original Message-----
From: postgis-users-admin at postgis.refractions.net
[mailto:postgis-users-admin at postgis.refractions.net]On Behalf Of Postgis
Sent: Monday, August 19, 2002 7:45 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] PostGIS vs Suse8.0
Is it possible to install PostGIS over working PostgreSQL installation
with Suse 8.0? Or do i have to compile postgresql form the source code then
compile postgis form the source code as indicated at installation text? Is
there any way to make it run over already installed system? If there is how?
Thanks..
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020819/f9ad1ecd/attachment.html>
