[postgis-users] OT: moving my access data into postgis
Thomas, Cord
cthomas at rand.org
Wed Aug 21 08:48:43 PDT 2002
Tyler,
depends on your tools and your goal i guess.
You are on windows, right - both MS Access and postgresql?
You have how many tables (just one)? Are they/it created in postgres
already?
Here is what i would do (coming from other database backgrounds):
export Access to text file
turn postgres logging/transactions off (if you want to improve speed -
which appears to be your goal)
wrap each data line in an insert into statement appropriate for the table
(should be easy with 4 integer fields) - you can use a simple regular
expression to do this.
execute the text file with psql. psql -d <database name> -f <text file>
Will still take a long time - i might even break the export of the data
into a few chunks because handling 0.5 million records in any envirnoment
is still burdensome.
Cord
-----Original Message-----
From: Tyler Mitchell [mailto:TMitchell at lignum.com]
Sent: Wednesday, August 21, 2002 8:44 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] OT: moving my access data into postgis
Slightly off topic, but relevant nonetheless.
I've got a ton of data in an MS Access database and I've been using the
postgresql odbc driver to export the data into a postgis database. But
man, it's really, really slow. You thought gist indexing of large tables
was slow! Well, I'm looking at 1-2 hours for half a million records with
only 4 integer columns.
Can you suggest a better method of moving out of Access?
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
