[postgis-users] OT: moving my access data into postgis
Tyler Mitchell
TMitchell at lignum.com
Wed Aug 21 09:00:09 PDT 2002
Thanks Rob and Cord,
I keep forgetting that Access can spit out text and keep trying to avoid
that intermediary step because I have dozens of tables to move :(
But you suggestions make sense and give me lots to chew on.
Tyler
"Robert W.
Burgholzer" To: Tyler Mitchell <TMitchell at lignum.com>
<rburghol at vt.edu> cc:
Fax to:
08/21/2002 08:52 Subject: RE: [postgis-users] OT: moving my access
AM data into postgis
safve as tab delimitted, then use postgresql's import functions. This
should
speed things up a ton.
http://128.173.218.154/reference/postgres/sql-copy.html
and
http://128.173.218.154/reference/postgres/populate.html
should give you some details.
hopethis helps,
rob
