[postgis-users] PostGIS vs Suse8.0
Chris Hodgson
chodgson at refractions.net
Mon Aug 26 10:23:16 PDT 2002
I might try downloading the the source rpm file, it should already be configured in the same way as the compiled version is... then put the postgis source in the contrib directory of the source, and follow the documentation from there...
Chris
----- Original Message -----
To: postgis-users at postgis.refractions.net
Sent: Tuesday, August 20, 2002 4:57 AM
Subject: Re: [postgis-users] PostGIS vs Suse8.0
Let me explain my stiuation. I have Suse 8.0 as an operating system. I installed Postgresql from the SuSE 8.0 installation cds. I have working copy of Postgresql. Now what should i do to make Postgis work under my system? Do i have to use source files form postgresql.org?
Sent: Monday, August 19, 2002 5:49 PM
Subject: RE: [postgis-users] PostGIS vs Suse8.0
From what I understand, you do not need to recompile postgresql from source, but youdo need to have the source code available in order to build postgis. Should be doable for you!
Tyler
-----Original Message-----
From: postgis-users-admin at postgis.refractions.net [mailto:postgis-users-admin at postgis.refractions.net]On Behalf Of Postgis
Sent: Monday, August 19, 2002 7:45 AM
Subject: [postgis-users] PostGIS vs Suse8.0
Is it possible to install PostGIS over working PostgreSQL installation with Suse 8.0? Or do i have to compile postgresql form the source code then compile postgis form the source code as indicated at installation text? Is there any way to make it run over already installed system? If there is how?
Thanks..
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020826/43ce58c3/attachment.html>
