[postgis-users] how to use postgis db with mapserver
Vinko Vrsalovic
vinko at cprsig.cl
Tue Dec 10 04:21:31 PST 2002
On Tue, Dec 10, 2002 at 09:50:41AM +0100, Alessandro Ceccotti wrote:
> Hello,
> I've imported my .shp map in Postgresql/postgis using shp2pgsql.
> Now, how can use it with mapserver?
If you're using plain MapServer and just want to display a PostGIS
layer, you must set the appropriate parameters in the .map file.
For instance:
LAYER
CONNECTION "user=XXXX dbname=YOURDB host=localhost port=5432 password="
CONNECTIONTYPE POSTGIS
DATA "the_geom from chile_poly"
LABELITEM "NOMBRE"
LABELMAXSCALE 1e+06
LABELMINSCALE 10000
NAME "Chile"
SIZEUNITS PIXELS
STATUS ON
SYMBOLSCALE 200000
TEMPLATE "VOID"
TOLERANCE 10
TOLERANCEUNITS METERS
TYPE POLYGON
UNITS METERS
CLASS
NAME "División Administrativa"
COLOR 255 255 204
MAXSIZE 100
MINSIZE 1
OUTLINECOLOR 255 255 204
SIZE 1
SYMBOL 0
END
END
As you can see, it's almost the same, with the exception of CONNECTION,
CONNECTIONTYPE and DATA.
You can use arbitrary SQL queries to obtain your data, also.
You can read more about this at:
http://postgis.refractions.net/docs/x549.html
and at:
http://mapserver.gis.umn.edu/doc36/mapfile-reference.html
Vinko Vrsalovic <el[|- at -|]vinko.cl>
http://www.cprsig.cl
