[postgis-users] Selecting geocoded postal codes within a given distance ( miles for example )
Sung-Gheel Jang
sjang3 at uiuc.edu
Mon Dec 16 12:00:10 PST 2002
Hello,
You had better project your dataset first according to a proper projection
such as UTM, state plane etc. I believe the decimal degress can't deal with
the surface distance. It's only for a location of the earth sphere.
Sung-Gheel
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of Hugh
W. O'Brien
Sent: Monday, December 16, 2002 1:42 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Selecting geocoded postal codes within a given
Dear List,
How would one go about selecting the geocoded postal codes within given
a distance ( say in miles ) of another geocoded postal code. Finding
the long/lat of the postal code we are searching around is simple ( no
help is needed there ). I have read/seen the faq for postgis. The
example given there using a bounding box doesn't really fit what I am
trying to do exactly because I will be dealing with degrees
longitude/latitude and miles ( the example in the faq uses meters
exclusively ).
Thanks in advance for any help you can give.
-- Hugh W. O'Brien
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
