[postgis-users] Selecting geocoded postal codes within a given distance ( miles for example )
Hugh W. O'Brien
hugho at intelis.com
Mon Dec 16 12:06:32 PST 2002
I probably should have posted that I am a noob to not only using PostGIS
but also using a spatial engine in general. So I am not familiar with
the terms UTM, state place. etc... So, how would one go about
projecting their longitude/latitude data into UTM for example. Would
doing so convert my degrees long/lat to actual distance units such that
the standard bounding box example in the FAQ would be applicable?
-- Hugh O'Brien
Sung-Gheel Jang wrote:
>Hello,
>You had better project your dataset first according to a proper projection
>such as UTM, state plane etc. I believe the decimal degress can't deal with
>the surface distance. It's only for a location of the earth sphere.
>Sung-Gheel
>-----Original Message-----
>From: postgis-users-bounces at postgis.refractions.net
>[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of Hugh
>W. O'Brien
>Sent: Monday, December 16, 2002 1:42 PM
>To: postgis-users at postgis.refractions.net
>Subject: [postgis-users] Selecting geocoded postal codes within a given
>Dear List,
>How would one go about selecting the geocoded postal codes within given
>a distance ( say in miles ) of another geocoded postal code. Finding
>the long/lat of the postal code we are searching around is simple ( no
>help is needed there ). I have read/seen the faq for postgis. The
>example given there using a bounding box doesn't really fit what I am
>trying to do exactly because I will be dealing with degrees
>longitude/latitude and miles ( the example in the faq uses meters
>exclusively ).
>Thanks in advance for any help you can give.
>-- Hugh W. O'Brien
>_______________________________________________
>postgis-users mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-users
