[postgis-users] Re: prime meridians for PROJ.4
Luís Mota
luis.mota at iscte.pt
Tue Dec 17 13:34:33 PST 2002
Hi Frank.
I finally found time to take a look into this new srs file.
I notice there are some differences... There are a lot of 'AUTHORITY'
values... Was there any other relevant change? The thing is that I was
'parsing' the old format to extract some of these attributes, and I must
revise this parsing now...
Best regards, Luís Mota
----- Original Message -----
To: "Luis Mota" <luis.mota at iscte.pt>
Cc: "postgis" <postgis-users at postgis.refractions.net>
Sent: Wednesday, December 11, 2002 2:41 PM
Subject: [postgis-users] Re: prime meridians for PROJ.4
> Luis,
> As requested I have prepared a new dump of the EPSG codes in what I hope
is
> PostGIS compatible form ... I haven't actually tested it. I will leave
that
> to you. This should include the +pm directives for prime meridians where
> appropriate.
> I generated this dump with the gdal/pymod/epsg_tr.py script to which I
have
> added the '-postgis' commandline option for generating SQL INSERT
statement
> format suitable for use to insert into the spatial reference system table
> in PostGIS. If you, or anyone else, needs to generate translations of the
> EPSG tables, it should be possible using this script.
> I would add that the script could be easily modified to translate
arbitrary
> sets of coordinate system definitions from other sources, such as ESRI
.prj
> files for instance.
> The sample translation can be found at:
> ftp://gdal.velocet.ca/pub/outgoing/new_epsg_srs.sql.gz
> Please let me know of any problems you encounter.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> postgis-users mailing list
