[postgis] Connection problem
Nicolas Ribot
nicol at ribot.com
Wed Feb 6 01:52:08 PST 2002
Hi Ross,
I'm using the same configuration to run some postgis tests (NT + cygwin and
Windows2000 +
cygwin).
Some tips:
- You should include the complete set of parameters in the connection string:
user= password= host= port=
- In some earlier MapServer versions, you must include a FILTER clause, even
if a full select is
intended. My mapfile looks like, for a layer:
layer
connectiontype postgis
name "communes"
CONNECTION "user=postgres password=postgres dbname=test_postgis
host=pc-dev1
port=5432"
DATA "geo_value from communes"
FILTER "1=1"
status on
type polygon
class
name "rien"
outlinecolor 0 0 0
end
end
- Finally, is postmaster running with the -i option ?
I hope this helps.
Nicolas
Searle Ross wrote:
I am having a problem connecting to postgres. I get the following error
msPOSTGISLayerOpen(): Query error. Error parsing POSTGIS connection
information
I have tried numerous permutations of the string as in the postgis docs
but no luck
The connection stuff in my mapfile is :-
LAYER
NAME bioreg
TYPE POLYGON
CONNECTIONTYPE postgis
CONNECTION "dbname=veg user=postgres"
DATA "geo_value from bio_reg2"
The environment I'm running in is postgres compiled under cygwin and the
winNT mapserv executable as compiled by Perry Nacionales
Any one got any ideas
Thanks
Ross
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Sponsored by VeriSign - The Value of Trust
When building an e-commerce site, you want to start with a
secure foundation. Learn how with VeriSign's FREE Guide.
http://us.click.yahoo.com/oCuuSA/XdiDAA/yigFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
