[postgis] Itasca demo and spatial reference systems
John Reid
jgreid at uow.edu.au
Wed Feb 13 06:33:49 PST 2002
Is this the right spatial reference system for the Itasca demo (from
postgresql/share/contrib/spatial_ref_sys.sql)?
srid = 26915
auth_name = ESRI
auth_srid = 26915 | srtext =
PROJCS["NAD_1983_UTM_Zone_15N",
GEOGCS["GCS_North_American_1983",
DATUM["D_North_American_1983",
SPHEROID["GRS_1980",6378137,298.257222101]],
PRIMEM["Greenwich",0],
UNIT["Degree",0.017453292519943295]],
PROJECTION["Transverse_Mercator"],
PARAMETER["False_Easting",500000],
PARAMETER["False_Northing",0],
PARAMETER["Central_Meridian",-93],
PARAMETER["Scale_Factor",0.9996],
PARAMETER["Latitude_Of_Origin",0],
UNIT["Meter",1]]
The create table entry contains a CHECK contraint on the srid. Any idea
where that came from? Does shp2pgsql create it automatically? It is
causing problems when I try to follow the instructions in
postgresql/share/contrib/README.postgis.
itasca=> update airports set the_geom = SetSRID(the_geom,26915);
ERROR: ExecReplace: rejected due to CHECK constraint $1
-- TOC Entry ID 32 (OID 41542)
-- Name: airports Type: TABLE Owner: pgis_user
CREATE TABLE "airports" (
"gid" integer,
"name" character varying,
"lat" double precision,
"lon" double precision,
"elevation" double precision,
"quadname" character varying,
"the_geom" geometry,
CHECK ((srid(the_geom) = -1)),
CHECK (((geometrytype(the_geom) = 'MULTIPOINT'::text) OR (the_geom
ISNULL)))
BTW, postgresql/share/contrib/README.postgis looks like it has an error
in line 81:
UPDATE TABLE <table> SET <geocolumn> = SetSRID(<geocolumn>,<SRID>);
should read:
UPDATE <table> SET <geocolumn> = SetSRID(<geocolumn>,<SRID>);
john reid e-mail jgreid at uow.edu.au
uproot your questions from their ground and the dangling roots will be
seen. more questions!
-mentat zensufi
apply standard disclaimers as desired...
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Sponsored by VeriSign - The Value of Trust
Secure all your Web servers now - with a proven 5-part
strategy. The FREE Server Security Guide shows you how.
http://us.click.yahoo.com/iWSNbC/VdiDAA/yigFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
