[postgis] Problems with INHERITS
lczub
lczub at t-online.de
Wed Feb 13 15:03:46 PST 2002
Moin,
I played a little with inheriting from tables with geometryfields.
The first result is, inserting geometries into a geometryfield, which is
inherited from another table, is possible.
CREATE TABEL aaa (field_a TYP_A);
SELECT AddGeometryColumn(..., 'aaa','a_geom',a_srid,'POINT',2);
CREATE TABEL bbb () INHERITS (aaa);
INSERT INTO bbb FIELDS field_a, a_geom VALUES (1, GeometryFromText(...));
The second result is, geometry-questions on this field did not
function. One reasone could be, that there exits no entry for tabel bbb
in the metadata-table GEOMETRY_COLUMNS after these steps. (cause
INHERITS is no OPEN GIS standard?)
Question 1
My first idea for a workaround was
- first creating table aaa without geometryfields,
- then creating table bbb with INHERITS and without geometryfields
- after these steps I create GeometryColumns for aaa and bbb seperatly
But this creates a failure during creating geometryfields for
table bbb.
ALTER TABLE: column name "a_geom" already exists in table "bbb"
(yes I want to use the same column-names!)
Well, then I started manipulation of the AddGeometryColumn and
changed "ALTR TABLE" into "ALTER TABLE ONLY". But then I get
the failure
parser: parse error at or near "ONLY"
Tests shows, that generaly "ONLY" did not funtion with ALTER
TABLE.
Well, is there a chance to combine inherits and geometryfields?
Question 2
Well , if I build up db the first time, the workaround (if it function) is ok.
But
how should I create a new table ccc, which even inherits from
table aaa and there are thousands of entries in table aaa?
Must I dump the table aaa + bbb, drop them and create aaa,
bbb and ccc completly new and load the dump?
Is there another way?
Question 3
Should I use INHERITS or not?
It seems as an usefull (Postgres specific) function.
The attachment inherit_problem.sql cointains my script for the test.
Gruß Luiko Czub
______________________________________________________
Luiko Czub
Stürtzelstraße 1 Tel.: ++49-761/8098-240
D-79106 Freiburg Email: lczub at t-online.de
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Sponsored by VeriSign - The Value of Trust
Secure all your Web servers now - with a proven 5-part
strategy. The FREE Server Security Guide shows you how.
http://us.click.yahoo.com/iWSNbC/VdiDAA/yigFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
-- Tabelle für Textsaetze
BEGIN;
CREATE TABLE dfk_textsatz (
kennzahl CHAR(4) NOT NULL,
flurkarte CHAR(8) NOT NULL,
rechtswert INTEGER NOT NULL,
hochwert INTEGER NOT NULL,
rw_bezug_delta INTEGER,
hw_bezug_delta INTEGER,
winkel NUMERIC(6,3),
inhalt VARCHAR(256)
-- Tabelle fuer Text um Geometriefeld ergaenzen
-- es gibt 2 Punktgeometriefelder
-- a) real_pos Position des Bezugspunktes
-- b) draw_pos Position, an der Text / Symbol platziert wird
-- DFK Daten beziehen sich auf GK-Bessel 4. Streifen,
-- es werden POINT mit 2 dimensionalen Koordinaten gespeichert
SELECT AddGeometryColumn('dfktest','dfk_textsatz','real_pos','31494','POINT',2);
SELECT AddGeometryColumn('dfktest','dfk_textsatz','draw_pos','31494','POINT',2);
-- wenn mit mapserver gearbeitet wird, wird UNIQUE Index auf oid benoetig
-- (siehe POSTGIS Manual Chapter 4. Using PostGis-Retrieving GIS Data
CREATE UNIQUE INDEX dfk_textsatz_oid ON dfk_textsatz ( oid );
-- Zur Suche nach Textinhalten INDEX auf Feld inhalt
CREATE INDEX dfk_textsatz_inhalt ON dfk_textsatz ( inhalt );
COMMIT;
-- Tabelle für Symbolsaetze
-- Aufbau entspricht 1:1 dem der Textsaetze, deshalb wird von dfk_textsatz geerbt
BEGIN;
CREATE TABLE dfk_symbolsatz () INHERITS ( dfk_textsatz );
-- INDEXE vererben sich nicht
CREATE UNIQUE INDEX dfk_symbolsatz_oid ON dfk_symbolsatz ( oid );
-- Zur Suche nach Symbolnummer INDEX auf Feld inhalt
CREATE INDEX dfk_symbolsatz_inhalt ON dfk_symbolsatz ( inhalt );
COMMIT;
-- Einfuegetest für dfk_textsatz
-- + 4350$30940519$ 48058953$ 55118938$+ 0$+ 0$149.842$Thomas-Mayer-Weg
BEGIN;
INSERT INTO dfk_textsatz (kennzahl, flurkarte, rechtswert, hochwert,
rw_bezug_delta, hw_bezug_delta, winkel, inhalt, real_pos, draw_pos)
VALUES (4350, 30940519 , 48058953 , 55118938, 0, 0, 149.842, 'Thomas-Mayer-Weg',
GeometryFromText('POINT (4480589.53 5551189.38)',31494),
GeometryFromText('POINT (4480589.53 5551189.38)',31494));
COMMIT;
-- Einfuegetest für dfk_symbolsatz
-- + 4450$30940519$ 48035847$ 55130613$+ 0$+ 0$364.673$290
BEGIN;
INSERT INTO dfk_symbolsatz (kennzahl, flurkarte, rechtswert, hochwert,
VALUES (4450, 30940519 , 48035847 , 55130613, 0, 0, 364.673, '290',
GeometryFromText('POINT (4480358.47 5551306.13)',31494),
GeometryFromText('POINT (4480358.47 5551306.13)',31494));
COMMIT;
-- noch mal eine Abfrage den Koordinatenwerten einer Punktgeometrie,
-- diesmal aber fuer ein ererbtes Geomeriefeld!
-- (es ist nicht in der MEtadataTabelle geometry_columns vermerkt)
-- ergebnis sollte sein
-- x | y | srid
-- 4480358.47 | 5551306.13 | 31494
SELECT X(real_pos), Y(real_pos), SRID(real_pos) FROM dfk_symbolsatz WHERE inhalt = '260';
-- x | y | srid
-- 4480589.53 | 5551189.38 | 31494
SELECT X(real_pos), Y(real_pos), SRID(real_pos) FROM ONLY dfk_textsatz WHERE flurkarte = 30940519;
