[postgis] Unable to drop contraint
John Reid jgreid at uow.edu.au
Wed Feb 13 15:00:16 PST 2002
In this particular case editing the load file is probably easier ;-)  I
can see why dropping a column is not implemented though.  When I was
thinking about it last night all sorts of potentially really scary
problems came up.  So, as long as you don't have *really* huge tables,
the solution below is the best one (other one I can think of is dumping,
dropping, editing the load file and reloading the table - probably a
better solution for large tables and low free space on the database
partition).  Just hope nobody wants to run a query while the maintenance
is being performed :-(
Paul Ramsey wrote:
>Create new table with same data def, but not constraint.
>Select data from old into new.
>Delete old.
>Rename new to old.
>John Reid wrote:
>>*@#%$!  Postgresql doesn't allow the dropping of a contraint using ALTER
>>TABLE.  Anyone have an alternative idea?
>>john reid                                     e-mail jgreid at uow.edu.au
>>uproot your questions from their ground and the dangling roots will be
>>seen.  more questions!
>>                                                       -mentat zensufi
>>apply standard disclaimers as desired...
>>To unsubscribe from this group, send an email to:
>>postgis-unsubscribe at yahoogroups.com
>>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
john reid                                    e-mail: jgreid at uow.edu.au
technical officer                               building 41, room G02A
school of geosciences                          phone: +61 02 4221 3963
university of wollongong                         fax: +61 02 4221 4250
nsw  2522  australia
                                                       -mentat zensufi
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Tiny Wireless Camera under $80!
Order Now! FREE VCR Commander!
Click Here - Only 1 Day Left!
http://us.click.yahoo.com/nuyOHD/7.PDAA/yigFAA/PhFolB/TM
