[postgis] Unable to drop contraint
John Reid
jgreid at uow.edu.au
Sat Feb 23 07:47:33 PST 2002
Another alternative is to directly manipulate the postgres system
catalogues (danger Will Robinson!!!!). You will need at least usesuper
rights (I tried only usecatupd with no joy - any idea what this actually
gives you? I thought it would allow modification of the catalogues but
obviously not). In the end I just logged in as the postgres user.
itasca=> select * from pg_relcheck where rcrelid = (select oid from
pg_class where relname = 'airports') and rcsrc = 'srid(the_geom) = -1)';
itasca=# delete from pg_relcheck where rcrelid = (select oid from
You will also need to decrement the relchecks field in pg_class:
update pg_class set relchecks = 1 where relname = 'airports';
Otherwise the following error occurs:
itasca=> update airports set the_geom = SetSRID(the_geom,26915);
ERROR: RelCheckFetch: 1 record not found for rel airports
Then, what do you know, it does work:
UPDATE 12
Wonder what else I just broke....
cheers,
John
Paul Ramsey wrote:
>Create new table with same data def, but not constraint.
>Select data from old into new.
>Delete old.
>Rename new to old.
>John Reid wrote:
>>*@#%$! Postgresql doesn't allow the dropping of a contraint using ALTER
>>TABLE. Anyone have an alternative idea?
>>john reid e-mail jgreid at uow.edu.au
>>uproot your questions from their ground and the dangling roots will be
>>seen. more questions!
>> -mentat zensufi
>>apply standard disclaimers as desired...
>>To unsubscribe from this group, send an email to:
>>postgis-unsubscribe at yahoogroups.com
>>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
-mentat zensufi
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Tiny Wireless Camera under $80!
Order Now! FREE VCR Commander!
Click Here - Only 1 Day Left!
http://us.click.yahoo.com/nuyOHD/7.PDAA/yigFAA/PhFolB/TM
