[postgis] Re: itasca load issues
Tyler Mitchell
tmitchell at lignum.com
Thu Feb 14 10:45:35 PST 2002
Hi John,
Thanks for testing this out.
>Also, a couple of queries about the data:
>- what was the source (mapserver demo)?
Source was the Mapserver 3.5 demo data
>- how did you load it (from demo shapefiles using shp2pgsql)?
Yes, I used shp2pgsql to create sql files, then ran them.
>- what is the coordinate system is the data in? I take it from the
>demo.map file distributed with the mapserver demo that it is the
following?
>#PROJECTION
># "proj=utm"
># "ellps=GRS80"
># "zone=15"
># "north"
># "no_defs"
>#END
Yup, same as the demo settings.
Anyone give me more suggestions on how to "properly" export/dump the data
to avoid the problems John has mentioned?
Tyler
John Reid
<jgreid at uow.ed To: Tyler Mitchell <tmitchell at lignum.com>
u.au> cc: postgis at yahoogroups.com
Fax to:
02/13/2002 Subject: itasca load issues
05:04 AM
I managed to load the data using the procedure outlined below. I have
posted the relevant preliminary files at
http://www.uow.edu.au/~jgreid/postgis/. Some difficulties encountered
are noted as well. These were using v0.6.2, don't know what
implications for cvs version are.
demo.map file distributed with the mapserver demo that it is the following?
#PROJECTION
# "proj=utm"
# "ellps=GRS80"
# "zone=15"
# "north"
# "no_defs"
#END
cheers,
John
Procedure followed:
Preliminary:
1. removed type definitions from load file
2. replace references to root with pgisuser
3. modified the postgis_groups.sql file (including granting update
priviledge on geometry_tables for pgisusers)
Steps followed to load data:
$ su postgres
(or user with the usecreatedb privilege)
$ createdb itasca
$ psql -f /usr/lib/postgresql/share/contrib/postgis.sql -d itasca
(modify path to point to the local postgresql installation. The user
performing this operation requires usecatupd (and others?) privilege? I
can't find description of these privileges in the postgresql docs)
$ psql -ef postgis_groups.sql -d itasca
$ su pgisuser
$ psql -ef itasca.sql itasca
Couple of other matters:
Existing gives 2 classes of errors:
1. User does not have rights to update geometry_columns when loading
data from a dump file.
If I grok the purpose of this relation correctly, the most elegant
solution here would be tuple level access control - users should have
add (but not modify rights to existing tuples), with full control on an
individual tuple granted to the creator/owner. Also, if (when?) support
for SQL information schemas is provided by PostgreSQL this might not be
an issue. However I am not sure what the best solution is at the moment.
I have added the statement "GRANT INSERT ON geometry_columns TO GROUP
pgis_users;" to postgis_groups.sql. However this is not a good
solution, because if a table containing geometry is dropped this will
leave the database in an inaccurate state. On the gripping hand, this
still gives the following errors, which is *not* what I would expect
from the reference page for GRANT :-( Looks like UPDATE might be needed
as well... try that.... Yep. That works. What gives with INSERT
though????
INSERT INTO "geometry_columns" VALUES
('','itasca','ctybdpy2','the_geom',2,-1,'MULTIPOLYGON');
psql:itasca.jgr.sql:302: ERROR: geometry_columns: Permission denied.
('','itasca','twprgpy3','the_geom',2,-1,'MULTIPOLYGON');
psql:itasca.jgr.sql:303: ERROR: geometry_columns: Permission denied.
('','itasca','mcdrdln3','the_geom',2,-1,'MULTILINESTRING');
psql:itasca.jgr.sql:304: ERROR: geometry_columns: Permission denied.
('','itasca','lakespy2','the_geom',2,-1,'MULTIPOLYGON');
psql:itasca.jgr.sql:305: ERROR: geometry_columns: Permission denied.
('','itasca','stprkpy3','the_geom',2,-1,'MULTIPOLYGON');
psql:itasca.jgr.sql:306: ERROR: geometry_columns: Permission denied.
('','itasca','mcd90py2','the_geom',2,-1,'MULTIPOLYGON');
psql:itasca.jgr.sql:307: ERROR: geometry_columns: Permission denied.
('','itasca','majrdln3','the_geom',2,-1,'MULTILINESTRING');
psql:itasca.jgr.sql:308: ERROR: geometry_columns: Permission denied.
('','itasca','ctyrdln3','the_geom',2,-1,'MULTILINESTRING');
psql:itasca.jgr.sql:309: ERROR: geometry_columns: Permission denied.
('','itasca','twprdln3','the_geom',2,-1,'MULTILINESTRING');
psql:itasca.jgr.sql:310: ERROR: geometry_columns: Permission denied.
('','itasca','dlgstln2','the_geom',2,-1,'MULTILINESTRING');
psql:itasca.jgr.sql:311: ERROR: geometry_columns: Permission denied.
('','itasca','plsscpy3','the_geom',2,-1,'MULTIPOLYGON');
psql:itasca.jgr.sql:312: ERROR: geometry_columns: Permission denied.
('','itasca','airports','the_geom',2,-1,'MULTIPOINT');
psql:itasca.jgr.sql:313: ERROR: geometry_columns: Permission denied.
2. Problem with the dataset? (due to "open" polygon or overshoot?)
INSERT INTO "lakespy2" VALUES
(676,4204838.29762,22453.89536,421,'31065300',1,'NORTHSTAR',25,1358,1039.016,73671.231,'SRID
-1;MULTIPOLYGON(((451130.744395544
5265876.06652514,
<snip>
,449376.413561779 5265970.38791527)))');
psql:itasca.jgr.sql:1963: ERROR: polygon has ring where first point !=
last point
INSERT INTO "ctybdpy2" VALUES
(52,1518752180.39514,179570.98876,'Traverse',78,'TRAV','N',155,53,'SRID
=-1;MULTIPOLYGON(((247193.116832133
5101650.47120163,247192.24185142 5101634.50237652,
<snip>
,245591.122091334 5101713.47320567,247193.116832133 5101650.47120163)))');
psql:itasca.jgr.sql:467: ERROR: polygon has ring where first point !=
last point
john reid e-mail jgreid at uow.edu.au
uproot your questions from their ground and the dangling roots will be
seen. more questions!
-mentat zensufi
apply standard disclaimers as desired...
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Sponsored by VeriSign - The Value of Trust
Pinpoint the right security solution for your company - FREE
Guide from industry leader VeriSign gives you all the facts.
http://us.click.yahoo.com/pCuuSA/WdiDAA/yigFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
