[postgis] Re: [mapserver-users] Demo using PostGIS ...
Paul Ramsey pramsey at refractions.net
Tue Jan 22 09:09:20 PST 2002
Tyler Mitchell wrote:
> I've imported all the shapefiles into a postgis database called "itasca"
> (imagine that :).
> I'm new to postgresql, but have managed to dump out this database into some
> sort of file.
> Can someone please comment on the best way to dump this database, so that
> others could import the demo data quickly and easily?
pg_dump --inserts -C -t itasca itasca > itasca.sql
then edit the sql file so that (a) the table creation is done by first
creating the attribute table then running AddGeometryColumn and (b)
wrapping the inserts with BEGIN and END transaction blocks. You might
also want to ensure that the geometries have an explicit SRID and that
an appropriate row exists in SPATIAL_REF_SYS. IE, make it so that
loading the dump will result in a perfect PostGIS db, requiring no
fiddling at all.
> I'll make a tar.gz and forward it to you Steve, along with a new demo.map,
> but need some help on the syntax of the pg_dump command.
> Here's what I did - will it suffice?
>  pg_dump -C --file=itasca_dump.sql.tar --format t -a --superuser=postgres
> itasca
> and here are the files it produced:
> 16.dat  19.dat  22.dat  25.dat  28.dat  31.dat
> 17.dat  20.dat  23.dat  26.dat  29.dat  restore.sql
> 18.dat  21.dat  24.dat  27.dat  30.dat  toc.dat
>                     "Steve Lime"
>                     <steve.lime at dnr.st       To:     <mapserver-users at lists.gis.umn.edu>, <raanders at tincan.org>,
>                     ate.mn.us>                <postgis at yahoogroups.com>
>                                              cc:
>                     01/18/2002 07:27         Fax to:
>                     AM                       Subject:     [postgis] Re: [mapserver-users] Demo using PostGIS ...
>                     Please respond to
>                     postgis
> It would be interesting to have a postGIS ready version of the
> shapefiles used in
> the itasca demo. Perhaps someone could prepare that? It could be
> distributed,
> along with a PostGIS version of the map file as part of the main demo.
> I'd take
> care of that part if the data were somehow available.
> Steve
> Stephen Lime
> Data & Applications Manager
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> >>> "Roderick A. Anderson" <raanders at tincan.org> 01/17/02 08:15PM >>>
> I'm bringing a new PostgreSQL testbed server online in the next few
> days.  Since I can't seem to find the time to get good PostGIS data
> and
> learn the fun parts of mapserver I'd like to offer access to the
> server
> for the data for a demo using PostGIS and mapserver.  I'll learn by
> copying the work of great minds.
>    I'm thinking a readonly database and I may have to throttle it some
> if it starts eating too much bandwidth.
> This make sense and is there any interest with these caveats?
> Cheers,
> Rod
>                       Let Accuracy Triumph Over Victory
>                                                        Zetetic
> Institute
>                                                         "David's
> Sling"
>                                                          Marc Stiegler
> To unsubscribe from this group, send an email to:
> postgis-unsubscribe at yahoogroups.com
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
      __
     | Paul Ramsey
     | Refractions Research
     | Email: pramsey at refractions.net
     | Phone: (250) 885-0632
     \_
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Sponsored by VeriSign - The Value of Trust
Secure all your Web servers now - with a proven 5-part
strategy. The FREE Server Security Guide shows you how.
http://us.click.yahoo.com/uCuuSA/VdiDAA/yigFAA/PhFolB/TM
