[postgis] Re: [mapserver-users] Demo using PostGIS ...
Tyler Mitchell
tmitchell at lignum.com
Tue Jan 22 09:29:53 PST 2002
>pg_dump --inserts -C -t itasca itasca > itasca.sql
This will only dump an individual table right? Is that what you recommend?
I would like to dump the whole user. Would that make it so that I could by
pass your other setup steps?
>then edit the sql file so that (a) the table creation is done by first
>creating the attribute table then running AddGeometryColumn and (b)
>wrapping the inserts with BEGIN and END transaction blocks. You might
>also want to ensure that the geometries have an explicit SRID and that
>an appropriate row exists in SPATIAL_REF_SYS. IE, make it so that
>loading the dump will result in a perfect PostGIS db, requiring no
>fiddling at all.
Tyler
Paul Ramsey
<pramsey at refrac To: postgis at yahoogroups.com
tions.net> cc:
Fax to:
01/22/2002 Subject: Re: [postgis] Re: [mapserver-users] Demo using PostGIS ...
09:09 AM
Please respond
to postgis
fiddling at all.
> I'll make a tar.gz and forward it to you Steve, along with a new
demo.map,
> but need some help on the syntax of the pg_dump command.
> Here's what I did - will it suffice?
> pg_dump -C --file=itasca_dump.sql.tar --format t -a --superuser=postgres
> itasca
> and here are the files it produced:
> 16.dat 19.dat 22.dat 25.dat 28.dat 31.dat
> 17.dat 20.dat 23.dat 26.dat 29.dat restore.sql
> 18.dat 21.dat 24.dat 27.dat 30.dat toc.dat
> "Steve Lime"
> <steve.lime at dnr.st To:
<mapserver-users at lists.gis.umn.edu>, <raanders at tincan.org>,
> ate.mn.us> <postgis at yahoogroups.com>
> cc:
> 01/18/2002 07:27 Fax to:
> AM Subject: [postgis] Re:
> Please respond to
> postgis
> It would be interesting to have a postGIS ready version of the
> shapefiles used in
> the itasca demo. Perhaps someone could prepare that? It could be
> distributed,
> along with a PostGIS version of the map file as part of the main demo.
> I'd take
> care of that part if the data were somehow available.
> Steve
> Stephen Lime
> Data & Applications Manager
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> >>> "Roderick A. Anderson" <raanders at tincan.org> 01/17/02 08:15PM >>>
> I'm bringing a new PostgreSQL testbed server online in the next few
> days. Since I can't seem to find the time to get good PostGIS data
> and
> learn the fun parts of mapserver I'd like to offer access to the
> server
> for the data for a demo using PostGIS and mapserver. I'll learn by
> copying the work of great minds.
> I'm thinking a readonly database and I may have to throttle it some
> if it starts eating too much bandwidth.
> This make sense and is there any interest with these caveats?
> Cheers,
> Rod
> Let Accuracy Triumph Over Victory
> Zetetic
> Institute
> "David's
> Sling"
> Marc Stiegler
> To unsubscribe from this group, send an email to:
> postgis-unsubscribe at yahoogroups.com
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Tiny Wireless Camera under $80!
Order Now! FREE VCR Commander!
Click Here - Only 1 Day Left!
http://us.click.yahoo.com/WoOlbB/7.PDAA/ySSFAA/PhFolB/TM
