[postgis] Re: Installation on Windows 2000 using Cygwin
mjfan823
mjfan823 at yahoo.com
Wed Jan 23 02:02:12 PST 2002
Im also trying to install PostGreSql on Windows 2000 using Cygwin,
but I had a different problem, I followed the follwing steps
described by Mr. Kevin Lo:
1. Download PostgreSQL 7.1.2 sourcecode in /usr/src.
2. tar zxvf postgresql-7.1.2.tar.gz
3. mkdir -p /usr/local/pgsql/{bin,include,lib,data}
4. cd /usr/src/postgresql-7.1.2, then run './configure'
5. make; make install
6. cp/usr/local/pgsql/lib/pq.dll /usr/local/pgsql/bin
7. Usingany editor to create .bashrc in / directory as belows:
PATH=$PATH:/usr/local/pgsql/bin:/usr/local/bin
PGDATA=/usr/local/pgsql/data
PGLIB=/usr/local/pgsql/lib
LD_LIBRARY_PATH=/usr/local/pgsql/lib:/usr/local/lib
export LD_LIBRARY_PATH PATH PGDATA PGLIB
8. source /.bashrc, then run ``ipc-daemon &''
9. initdb
Note that the owner of the DB system have to be different from
root/administrator
10. Editthe file /usr/local/pgsql/data/pg_hba.conf, such as:
host all 211.21.80.132 255.255.255.0 trust
11. postmaster-i&
12. Run 'psql -h host_name template1'. It's easy, huh :-)
I had some problems during running the make file:
/usr/lib/gcc -lib/i686-pc-cygwin/2.95.3-5/../../../../i686-pc-
cygwin/bin/ld:cannot find -lcrypt
collect2: ld returned 1 exit status
make[2]: *** [postgres] Error 1
make[2]: Leaving directory '/usr/src/postgresql-7.1.3/src/backend'
make[1]: *** [install] Error 2
make[1]: Leaving directory '/usr/src/postgresql-7.1.3/src'
make: *** [install] Error 2
Could anyone show me what I'm missing, I read a reply in one of the
forums saying that he was able to install the postgresql properly by
following the said instructions to the letter. Thanks in advance!
Raymond
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Tiny Wireless Camera under $80!
Order Now! FREE VCR Commander!
Click Here - Only 1 Day Left!
http://us.click.yahoo.com/nuyOHD/7.PDAA/yigFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
