[postgis] ERROR: parser: parse error at or near "with"
José María Michia jmmichia at ciudad.com.ar
Thu Jan 31 00:26:12 PST 2002
Español:
Hola!
Cuando ejecuto "psql -f postgis.sql -d databasename" obtengo los
siguientes errores:
1- ERROR:  parser: parse error at or near "with"
2- ERROR:  parser: parse error at or near ","
Estos errores se repiten muchas veces.
Edite el archivo postgis.sql y elimine todos los with(.........) y todos
los ,'.......' que traian problemas. Luego:
psql -f postgis.sql -d databasename         OK
CREATE TABLE geom_test ( gid int4, geom geometry,name varchar(25) );
    OK
INSERT INTO geom_test ( gid, geom, name ) VALUES ( 1, 'POLYGON((0 0 0,0
5 0,5 5 0,5 0 0,0 0 0))', '3D Square');        ERROR
ERROR:  Load of file /usr/local/pgsql/lib/contrib/libpostgis.so.0.6
failed: /usr/local/pgsql/lib/contrib/libpostgis.so.0.6: undefined
symbol: LocalBufferBlockPointers
Gracias
ENGLISH???
Hello!
# "psql -f postgis.sql -d databasename"
1- ERROR:  parser: parse error at or near "with"    (many times)
2- ERROR:  parser: parse error at or near ","    (many times)
In postgis.sql, delete every occurrence of [with(...)] and [,'........']
try again:
    OK
Thanks
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Sponsored by VeriSign - The Value of Trust
Secure all your Web servers now - with a proven 5-part
strategy. The FREE Server Security Guide shows you how.
http://us.click.yahoo.com/iWSNbC/VdiDAA/yigFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
